Running Conditioner Out Door | FerrariChat
Discussion in '458 Italia/488/F8' started by agentbb007, May 15, 2016.
  1. agentbb007
    agentbb007 Karting
    Sep 25, 2009
    63
    Strider
    #1 agentbb007, May 15, 2016
    I fell like a total dunce but I cannot for the life figure out how you are supposed to run the battery conditioner on the 458 out the passenger door without pinching the cable. The manual says to run it under the passenger door on the front side, but I can't get the cable to slide to the front side because the door is pinching it.
    Any photos or even a video would be even better if someone could post one.
    BB
  2. Dolceexte
    Dolceexte Formula 3
    Dec 20, 2015
    1,008
    I run it through the window open, and draped a cloth to protect inside and outside contact points.
    Haven't figured out the door either.
  3. 2Veloce
    2Veloce Formula Junior
    Aug 8, 2014
    566
    annapolis, maryland
    Al
    i also run it through the window. I wanted to see the area under the door to make sure there was a "channel." Didn't see it and didn't want to leave it up to chance that its soft enough not to damage the wire. I figure i can see the wire going out the window so i wouldn't take off with the wire attached! ( under the door is another story)...
  4. agentbb007
    agentbb007 Karting
    Sep 25, 2009
    63
    Strider
    Ok thanks guys, I think I will just stick with the open window as well :)
  5. Dolceexte
    Dolceexte Formula 3
    Dec 20, 2015
    1,008
    I use a long cloth to drape over the entire external door and window; all contact is with the cloth. Thank goodness they made it external in the T and models after.
  6. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    So. Cal and No. Utah
    Rick
    I run mine exactly where you show in your picture. It doesn't hurt anything :)
  7. Newjoint
    Newjoint Formula 3
    Jan 17, 2016
    1,463
    The battery tender unit sits on the floor outside the door and the smaller cable is run over the door sill and door is closed. The rubber seal of the door indents but not the cable
  8. mholifield
    mholifield Rookie
    Jun 25, 2007
    22
    Atlanta GA
    Mark Holifield
    +1
  9. Randyslovis
    Randyslovis Formula Junior
    Jul 7, 2011
    897
    Atlanta, GA
    Randall J Slovis
    You are almost there. Meaning, if you slide the cable forward until it is at leading edge of door, then close door, you can slide the cable forward the last 1" or so. It will now be in the "groove" where front fender and door meet. The cord will be "loose" as not compressed by door in this position. You are correct, if you close door and leave wire 3-4" from door edge it is at some level trapped/pinched". To disconnect the wire, gently slide the wire back an inch or so, then open door and you are good to go. If I don't slide wire back, sometimes it hangs up in the door/fender groove.
    I prefer not to have window open. Want to try and keep that wonderful Ferrari smell forever!
    Best
  10. Matt_337
    Matt_337 Karting
    Dec 24, 2003
    102
    Texas
    Matt
    Lol. Me too.
    I used to do it with the window open but didn't want to lose the smell so I've been trying to find this groove you're talking about. Now I just close it on the cord.
