Running costs, 458C vs 430C | FerrariChat
Discussion in 'Challenge/GT Cars/Track' started by fire_n_ice, Feb 19, 2016.
  1. fire_n_ice
    fire_n_ice Formula 3
    Jun 9, 2006
    1,087
    Can anybody provide insight into the running costs of a 430 Challenge car vs a 458 Challenge car. Apart from the difference in the price of the car, is the 458C significantly more expensive to run and maintain for 8-10 track days a season, for example? I know the gearbox is fundamentally different.
    Also, I would assume it easier to get 458C parts as that is the current car, but is it already difficult to get parts for the 430C?
    Thank you.
  2. 24000rpm
    24000rpm F1 Rookie
    #2 24000rpm, Feb 22, 2016
    the only thing I know is getting parts for 430c is relatively easy. I've ordered a bunch of 430c and 360c parts ( some of them are identical to street versions, some of them are not)
    parts I ordered include all oil hoses and water hoses, all regular maintenance parts like clutch, tob, rims, a-arms, a shock, all suspension bushings, various engine gaskets. etc etc . I've yet to rebuild an engine. but last time I asked the vendor he said he can have 430 pistons and 360 pistons in 1 week.
    Never let down. for 458, i don't know, but I assume its easy as well, as you said, its newer car.
    edit. I ordered parts from a european vendor, lead time is usually 1-2 weeks.
  3. fire_n_ice
    Jun 9, 2006
    1,087
    That is great information, thank you very much.
    I'd heard the 458C series has mandated gearbox replacements every few races. Is that true? I'm not a huge fan of DCT gearboxes for racecars, although I believe even the new Cayman GT4 racecar has a PDK.
    Sent from my SM-G925W8 using Tapatalk
  4. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,830
    Dallas Texas
    If you know you know
    That is not true.
    We ran several cars in 2015 without replacing driveline componants. They have proven to be quite reliable...
    S
  5. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,830
    Dallas Texas
    #5 SAFE4NOW, Feb 22, 2016
    FWIW , actual running cost are close to the same, it's what experience you are wanting at the track that can make the difference.
    If you are ok running out of a featherlite 28' pulled behind a dually
    vs
  6. 24000rpm
    24000rpm F1 Rookie
    recently put up an order and only 1 part they had a problem
    part # 179070
    and here's what the vendor said: "ferrari currently have problems with these as the put 430 bearing in the 360 boxes. And they don't work the same "
