Running Hot | FerrariChat
Running Hot
Discussion in '348/355' started by nbenz, May 31, 2012.
  1. nbenz
    nbenz Rookie
    Sep 27, 2010
    37
    Severna Park, MD
    Neil Benz
    Took it for a ride today and the temperature stayed around 180 even at speed in 75 degree weather. Plenty of antifreeze, could it be water pump? How can I check?
  2. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    I'd check first that both fans are coming on. If that checked out I would then check for a stuck thermostat. You would hear a seized pump or one with bad bearings...
  3. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,895
    Richmond
    Pete
    180F? If so, that's normal...
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Within the normal range.
  5. MicroFirm
    MicroFirm Karting
    Dec 6, 2010
    231
    Colorado
    Frank
    Mine runs at 190 or slightly below all the time.
  6. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Honolulu - Seattle - Okinawa
    Steve
    Sounds normal to me too. 180 isn't that warm for coolent.
  7. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Mine is always around 190 F degrees.
    Sounds right on the money to me.
  8. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    180º is normal.
  9. Docopp
    Docopp Karting
    Aug 28, 2011
    91
    Crosby Texas
    Ed
    I put in hyperflow cats...
    temperature dropped 15 degrees !!!!
    Before, with stock cats, my gas cop would get hot, very hot to touch, now not even warm.
  10. nbenz
    nbenz Rookie
    Sep 27, 2010
    37
    Severna Park, MD
    Neil Benz
    wow, my was running in the 160 range when on the highway, then would only get to 190 when stuck at a light for a while. Just yesterday I noticed it would not go lower then 180 and stayed close to 190 the whole time. Fans work, I can hear them kick on once near 190. I tried going faster, but that did not work, I will just try to keep driving faster.
    Thanks...
  11. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,727
    180dF is actually lower than desired, especially if/when the oil temp is also down that low. Some of the additive/anti-wear package in oils do not start to work until the oil is above 200dF.
    But, my car with its previous thermostat would run this cold (thermostatic lower limit) with the new thermostat it tends to run no cooler than 195dF.
  12. White Knight
    White Knight Formula 3
    Aug 22, 2011
    1,531
    Ogden, UT
    Todd S.
    Sounds fine to me. Mine tends to run on the cool side unless I get going for an hour or two of spirited driving, then things will run around 180 F and 200-210 F for the oil
  13. FDT
    FDT Formula Junior
    May 18, 2010
    423
    La
    Ric
    180 is when the condensation starts to really boil off. It is normal
  14. nbenz
    nbenz Rookie
    Sep 27, 2010
    37
    Severna Park, MD
    Neil Benz
    So what would be considered a high temperature to be worried about overheating?
  15. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,895
    Richmond
    Pete
    I'd probably start to be concerned at 220 and make a move to get off the road and let it cool down. Red looks like 240 ish which is where it will start to overheat and where I'd pull over and shut it down. I've never seen mine go over 195, but it seems to get to 190-195 whenever I'm stuck in traffic. If it hit 220, I'd probably take the next exit or stop at the next gas station. If it hit 240, I'd pull over immediately and shut it down.
  16. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Huntington Beach, CA
    Lou Boyer
    Sounds like we were talking water temp, and now possibly oil temp.....
  17. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    Mine was running a little hot and the fans whould always be ON. I found that my antifreeze/water ratio was (60/40). I did a coolant flush and reduced the antifreeze/water ratio to 40/60. The running temperature dropped drasticly.
  18. nbenz
    nbenz Rookie
    Sep 27, 2010
    37
    Severna Park, MD
    Neil Benz
    Put on the Challenge grill today and it lowered the temps a lot. I have never seen mine over about 192, so I assume I am good. Thanks all.
  19. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    Mine runs 190 all day. 180 is normal.
    --Mike
  20. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 ........ going down to 160° F is not good, it shows thermostat may be stuck open, which would affect the ECU's ability to properly administer A/F ratio. That lower temp reading may cause a rich condition (ECU thinks engine is cool) and the extra fuel would kill the cats.
  21. nbenz
    nbenz Rookie
    Sep 27, 2010
    37
    Severna Park, MD
    Neil Benz
    cats what cats? Once I put the gothspeed exhaust in did the fabspeed headers and test pipes. The sound it unreal. Seems to be running constant 180-190, so looks like I am good now.
  22. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    I noticed something yesterday. It was 94 degrees Fahrenheit and the car was reading 190 -210 on my drive. It gets up to 210 sometimes when sitting at a stop light before the fan kicks on. What I thought was strange is when water temp gauge was reading 190 degrees I shut the car off and the temp would then climb up to 210 when I checked it just a short time later.
    Why would the water temp rise after the car is shut down?
  23. MicroFirm
    MicroFirm Karting
    Dec 6, 2010
    231
    Colorado
    Frank
    It would rise from latent heat in the engine and no air or water flow to the radiators to dissipate it. I would think that's normal.
