348 - Running rich, then Limp Mode | FerrariChat
348 Running rich, then Limp Mode
Discussion in '348/355' started by Finpat, Jun 2, 2024.
  1. Finpat
    Finpat Karting
    Sep 17, 2021
    246
    Finland
    Kari Lehtinen
    Background
    The car is 1991 TS Euro model i.e. Motronic 2.5 (yes, only one TPS on 5-8 bank) and no CEL or ECU lights included. Plugs and wires done a year and 5000 km ago. 5-8 bank MAF changed to a no-name, China Inc. version same time as plugs and wires as the original one failed. Also new exhaust was installed during winter for this driving season, at time cats and O2 sensors, including wiring looked good per visual inspection.
    Symptoms
    Car run well last driving season (~ 4000km) and also started this season well (~ 1000km) but past couple of days there I have been smelling some gas fumes which I don't recall to have had earlier. Nothing overwhelming but clearly a scent of Eau de Benzina in the air. We have had abnormally warm May here in Frozen Tundra, day temperatures in +27C° / 80F° range and classified this new odor as side effect of warm ambient temperature. Gas scent is around only when engine runs.
    Yesterday after dropping Mrs. to local ladies wine tasting event at city center and driving back in a stop-and-go traffic suddenly engine sounds changed to more mellow note, idle dropped a 100 rpm or so and about 200 - 250 horses escaped from engine bay. No problems to driving home, though. Everything felt smooth while driving and idle at the stop lights was steady but lower. No CEL because there is not a bulb in the holder. And I didn't see slow down light either. It was just a 50 - 100 hp version of 348.
    My assumption
    I assume that engine went to limp mode and dropped a bank due to excessive heat on one of the cats. And this overheating is due to excessive rich AFR. So a real issue instead of Cat Temp ECU ghost.
    And primary reason for too rich AFR would likely be China Inc. MAF reaching the of its life span i.e. 12 months or so.
    Or it could be one of the n+1 other issues which could be found in a 33 year old Italian car...
    Question
    What kind of troubleshooting procedure would be most appropriate to verify the root cause?
    - Driving to a local indy shop with exhaust gas analyser to verify if the AFR really is too rich?
    - Do Euro cars have any carbon cans etc. systems which might cause gas door while engine is running?
    - Any idea is appreciated!
  2. Qavion
    Qavion F1 World Champ
    14,259
    Ian Riddell
    Are the fumes coming from the tailpipes or from the engine bay. Perhaps check the evaporative system plumbing between the charcoal canister and the intake manifolds (if Euro cars have this plumbing).
    It might cause some of the symptoms, but I don't know if/how it would affect the idle (?).
  3. Gargamel647
    Gargamel647 Rookie
    Apr 11, 2021
    20
    Las Vegas
    Vincent Vitale
    I had a similar issue and I had to adjust the CO on the MAF. Does the Chinese MAF have an adjustment? I attempted to put one in but aborted mission when I couldn't get a good OHM reading from the Chinese MAF. Ended up putting a Saab MAF in.
  4. Aeroflop
    Aeroflop Karting
    Mar 1, 2022
    59
    Finland
    Eero Ahonen
    You can check the injector pulse width with oscilloscope, compare the non-running side with the running side. If the car wants to push huge amount of fuel because of MAF, it should be visible here. If the engine is running rich eg. because of broken FPR, it will not show here.
    You can also check with strobo that the spark is going to the plugs, just remember that 2 of the leads will give ugly or no signal due to the system.
    You can also check the fuel pressure with pressure gauge and AF mixture with a lambda sond.
    For some reason I have a fuel pressure gauge with compatible connectors, a lambda sond and AFR meter and an extra low-pressure FPR if you want help to search for the fault. Others I can loan, the FPR I can also sell if the fault is there. I live near enough to have a 348-blast at next weekend if you want me to sparr with the research.
    Oh, and to check the FPR's you'll need to either run the car or use a jump-wire instead of relay at the passenger footwell. The car will not run fuel pumps by just turning the ignition on - at least my won't.
  5. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,324
    Palos Verdes
    Vince V
    My car developed a rich condition and the shut down warning light. After MUCH ignition diagnostic work it was the FPR on one bank - it failed. If cylinder 1 or 5 are fouling, there you go. Replace your FPRs or better still upgrade to adjustables. Later I had to replace the O2 sensors since they were jacked up from the rich condition. Thankfully the cats seem fine.
  6. Finpat
    Finpat Karting
    Sep 17, 2021
    246
    Finland
    Kari Lehtinen
    Thank you for guidance!
    I hope FPRs are fine as both of them were changed to new Volvo/Bosch units only a year ago. But better to check also these.
  7. Finpat
    Finpat Karting
    Sep 17, 2021
    246
    Finland
    Kari Lehtinen
    I believe Euro cars with cats have the same charcoal canister system. Good point. Must check.
    Idle impact was highly likely a limp mode / bank shut down which could be the caused by too rich AFR. And evaporative system leak could cause too rich AFR.
  8. Finpat
    Finpat Karting
    Sep 17, 2021
    246
    Finland
    Kari Lehtinen
    I suspect MAF much more than FPR but first thing would be to verify if AF ratio is really, really rich.
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    Bad coil or power module on one bank.
  10. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Im shocked the Chinese mad works at all, internally they are totally wrong.
  11. vvassallo
    Aug 4, 2006
    8,324
    Palos Verdes
    Vince V
    I thought that the ECU only shuts down a bank under either a catastrophic event - like throwing a piston through one side of the block - or in response to the TCU reporting unsafe heat levels in the cat. In the latter case, that's a fuel, O2 sensor or cat problem, it seems to me. The TC is pretty unsophisticated and it only deals with measuring heat levels and flashing dash lights in response. I believe it does 1) nothing 2) lights up as a warning for the appropriate bank 3) shuts down the appropriate bank until a safe operating temp is restored. All in response to heat measured by the thermocouple in the cat. In my case, I could make a hard right and get the 5-8 bank light to go on even though the 1-4 bank was the culprit and was the one that typically lit up.
  12. m.stojanovic
    m.stojanovic F1 Rookie
    3,215
    Serbia - Niš
    Miroljub Stojanovic
    According to Kari, his 348 is Motronic 2.5 which, as far as I know, does not have bank shutdown function. When the EGT goes above the "dangerous" level, the Cat Temp ECU will only flash the SDL. This is if it is a CAT version. The 2.5 NON-CAT versions did not even have any Cat Temp ECU-s nor any Thermocouples.
    The problem Kari is experiencing is probably for other reasons and I would first test with another MAF in place of the China made one. After all they are just $20 at AliExpress (see at: https://www.aliexpress.com/item/1005006239858520.html?src=google&aff_fcid=c3cc6d682a4d40ccbd54990b01cb1b4c-1717387827443-07130-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=c3cc6d682a4d40ccbd54990b01cb1b4c-1717387827443-07130-UneMJZVf&terminal_id=427d56601cb94cf7879fc8499000b4e6&afSmartRedirect=y) so one could buy a few for diagnostics purposes and, perhaps, short time running. Otherwise, I heard from a parts supplier here in Kuala Lumpur, who once tried to sell China MAF-s (same generation as the 348's but for other cars), that, if they function at all, will usually last for 2-3 months.
  13. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    I can confirm what Miro said above that the 2.5 does not do a shut down if the cat ECU throws a solid light. I had a bad one on my car early in my ownership and it would throw a solid light sometime at cold start up as well as later when well warmed up. I had a very respected Ferrari independent mechanic look at me strangely when I drove in and told him not to worry about the light being on and the car would operate fine. What surprised me was the fact even being a Euro car it still had a 2.5. Always thought it was an '89 only use.
  14. m.stojanovic
    3,215
    Serbia - Niš
    Miroljub Stojanovic
    Yes, it is strange that Kari's 348 is, as he informed, 1991 model but Motronic 2.5. My 1991 348TB, UK spec, was Motronic 2.7. I also found info, posted on this forum in 2005, that the change from 2.5 to 2.7 took place some time during 1990, at serial number 86406 (my car was 88xxx).
    Kari, are you sure your car is 1991 model?
  15. Finpat
    Finpat Karting
    Sep 17, 2021
    246
    Finland
    Kari Lehtinen
    #15 Finpat, Jun 6, 2024
    Hmm.. That is interesting information. The symptoms were clearly pointing to bank shut down. But I hadn't chance to follow-up the situation as I had to leave to a business trip.
    Anyway. 1991 car but still 2.5 as there is only TPS.
    Once I get back from Barcelona I will take another China Inc. MAF from the shelf. When I got the China Inc. MAF I bought 3 pcs at the same token, just in case. Then again I could buy a pair of BOSCH from Miroljub shouldn't they be soooooooo expensive...
    Perhaps, it is time for a stand alone ECU project and say bye-bye to MAFs all together.
  16. m.stojanovic
    3,215
    Serbia - Niš
    Miroljub Stojanovic
    Have a look at your Cat Temp ECU-s. If the connector to the car harness (not the one for the Thermocouple) has 4 pins, it does not have bank shut-down. In the case of 2.7 (with shut-down function), the equivalent connector on the Cat Temp ECU has 6 pins.
    I noticed that the two Bosch MAF-s on Ebay have "or best offer" so they are open for some negotiation.
  17. johnk...
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    If the MAF is causing a rich condition shouldn't the O2 sensor tell the ECU to reduce the injector open time to lean it out? Ultimately, if it can not reduce the injector timing sufficiently to lean it out it would through a code for Lambda control.
  18. Finpat
    Finpat Karting
    Sep 17, 2021
    246
    Finland
    Kari Lehtinen
    Theme 1991 reoccurs in different plaques and stickers. Also on the original papers first registration is officially on 1991 in Monaco.
    But VIN is 85xxx...
    So, you are right car is likely 1990 production model, but was sold as 1991 model by Charles Pozzi S.A.
    Anyway, now to eat one more tapas dinner with customers and then early birdie flight back to home and I can do more fact checking.
  19. m.stojanovic
    3,215
    Serbia - Niš
    Miroljub Stojanovic
    Another easy check you can do is see the Bosch number on one of your engine ECU-s. Motronic 2.5 are Bosch 0 261 200 190 whereas Motronic 2.7 are Bosch 0 261 200 457, 0 261 200 489 or 0 261 203 327.
  20. Finpat
    Finpat Karting
    Sep 17, 2021
    246
    Finland
    Kari Lehtinen
    As it seems my Motronic 2.5 car doesn't have "bank shut down" -functionality then coil / power module could be an explanation for the symptoms I experienced. And it was exceptionally hot while driving in bumper to bumper traffic.
    I'll continue troubleshooting during weekend when I am in the same zip code with the car.
  21. johnk...
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    Coils and power modules are cheap. Both are standard Bosch parts.
    Ignition coil
    Bosch 0221503407
    Also 99-2004 Land Rover Discovery
    Ignition Power Module
    Bosch 0227 100 200
    Porsche part 99360270601 (94-95 911)
  22. m.stojanovic
    3,215
    Serbia - Niš
    Miroljub Stojanovic
    And a few more...
    Ignition Coil:
    PROTON WAJA PW811201 (WIRA, GEN2)
    Range Rover & Discovery (1999–2004)
    ALFA ROMEO 134386, 60558152, 60586072, 60809606, 7648797, 76487970
    AUDI 489 051 051
    CITROEN 5970.53, 134386, 60558152
    FIAT 60586072, 76487970
    HONDA 30520-PDF-E00, 30520-PDF-E01, 60558152
    KIA 95-97 0K011-18-100
    LANCIA 60586072, 76487970
    PEUGEOT 5970.53
    SEAT 489 051 051, ZS 234
    LAMBORGHINI 489 051 051
    MASERATI 134386, 76487970
    VW 048 905 105 1
    BOSCH 0 221 503 407
    HELLA 5DA 749 475-041
    BERU 0040100233, 0040100234, ZS234
    BREMI 11883
    FEBI BILSTEIN 36618, GN10 211
    DELPHI GN10211-12B1
    FACET 9.6068, EPS 1.970.168, KW 470 168
    HUCO ERR 6045, 138793
    METZGER 0880074, ERR6566
    NGK U2006, 48025
    BOUGICORD 155076
    INTERMOTOR 12623
    ERA 880131
    MEAT & DORIA 85.30097, 10311
    HOFFER 8010311
    TESLA CL302, CL544
    VALEO 24 51 66
    FAE 80279
    MAPCO 80001
    MARELLI 060810175010 BI0022MM BAE680AG
    Ignition Module:
    Alfa Romeo, Fiat 9607361280, 60809477, 60558153
    BMW 12141461441
    Citroen 96073612, 9607361280
    Opel 1208074, 90444650, 90449574
    Porsche 99360270600, 99360270601
    Peugeot 594554, 96073612
    Bosch 0 227 100 200
    MARELLI 940138514, 940038514010
    VALEO 245525
    BERU ZM026
    HÜCO 138401, 138402
    STANDARD LX-932
    HELLA 5DA 006 623-601
    Interchangeable BOSCH:
    0 227 100 201
    0 227 100 202
    0 227 100 204
    0 227 100 213
    0 227 100 215
  23. Finpat
    Finpat Karting
    Sep 17, 2021
    246
    Finland
    Kari Lehtinen
  24. Finpat
    Finpat Karting
    Sep 17, 2021
    246
    Finland
    Kari Lehtinen
    Now when car has been in garage 6 days it starts and drives normally. A quick around the blocks test drive that is, we are back in standard summer weather, +16C and sunny at 09:30 and heavy down pour at 09:42...
    On 5-8 bank side the there is one screw which attach coil to heat sink missing. I'll get that fixed at least.
  25. Finpat
    Finpat Karting
    Sep 17, 2021
    246
    Finland
    Kari Lehtinen
