rustproof inside the doors? | FerrariChat
Discussion in '206/246' started by outofpocket, Aug 25, 2013.
  1. outofpocket
    outofpocket Formula Junior
    Dec 6, 2007
    258
    Midwest
    GD
    #1 outofpocket, Aug 25, 2013
    While the trim is off what should I do about rustproofing the inside of the doors. The picture probably looks worse than it is as it is mostly surface rust. Somebody suggested using POR15 to coat the inside, but I've not had any experience with it.
    What has anyone else done? Or do I need to do anything?
  2. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    I think it depends on if you plan to expose it to water.
    If you live in a high-humidity area, plan to drive the car in the wet or wash it with the hose you should probably put something over the bare metal areas.
  3. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    You definitely need to do something.
    Use Dinitrol RC rust converter, it adds a film to the rust and stops it dead in its tracks. Once dry then coat with ML
    Waxoyl is another good product too.
    Classic Cars Dinitrol ML3125 Dinitrol 4941
  4. outofpocket
    Dec 6, 2007
    258
    Midwest
    GD
    What is ML?
  5. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    go to the dinitrol link and it tells you all about it.
  6. outofpocket
    Dec 6, 2007
    258
    Midwest
    GD
    The Dinitrol products are not available in the US. Is there an equivalent product available here?
  7. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
  8. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    Rust Reformer by RustOleum chemically converts rust to a black state which then CAN be painted if you choose to. When I got my car 20 yrs ago I painted this stuff on various underbody areas (inside the fenders by the headlights, etc) where I could see surface rust and it still looks the same. I think I got my last little jug at Pep Boys.
    I have heard of people using POR but never have myself, and Waxoyl has been used in England for decades.
  9. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    My problem with painting is that you could miss a bit in difficult to reach places, Waxoyl when applied hot (warm the can in a container of hot water) will creep everywhere and into the small cracks and seams. When it goes cold it dries to a semi hard state and is totally water proof.
    Perfect for inside 246 cills, doors and under wing areas etc
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    POR15 is excellent. It is necessary to carefully prepare the surface according to the directions (always good advice). It's practically a bulletproof coating when it dries.
  11. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    Agreed POR15 is a superb product. There is tons of information on it all over the internet so it is pretty easy to get some good research done before choosing to use it.
  12. Ducman491
    Ducman491 Formula 3
    Apr 9, 2004
    1,591
    Mentor OH
    Jason
    I have a body shop friend that uses automatic transmission fluid and swears by it. Make sure any drain passages are clear and wiring is covered and spray in the door.
  13. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    The Rust Reformer is a low-viscosity liquid, so it would run into small spaces well.
    I like that it chemically transforms rust into another inert compound.
    I guess you could apply Waxoyl over it if you wanted to after it has dried
    If you plan to spray the entire inside surfaces of sills, then you will need a more viscous material like Waxoyl so it will cling to the upper horizontal surfaces. Sounds like Waxoyl is similar to the Ziebart rust preventive treatments of old.
    In any case the most important thing is to make sure the drainage holes are not blocked.
  14. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    Jim
    Waxoyl & Dinitrol does the same thing by turning rust into an inert compound, apparently it also has the properties to soak into existing paintwork and attack rust beneath the paint. Something some products cannot do
    Cheers
    Tony
