Rusty Rotors After Washing | Page 2 | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Edwin_360, Aug 9, 2005.
Thread Status:
Not open for further replies.
  1. Sfumato
    Sfumato F1 World Champ
    Nov 1, 2003
    10,194
    Llanfairpwllgwyngyll, Anglesey, Wales
    Angus Podgorney
    Rotate your bulbs
  2. Etcetera
    Etcetera Two Time F1 World Champ
    24,372
    C6H14O5
    And replace them if they start blinking.
  3. jmelcher
    jmelcher Rookie
    Aug 8, 2005
    3
    A little silicone paste will not only protect the surface from rust, it will also reduce the excessive heat created during hard braking.
  4. Dino Martini
    Dino Martini F1 Rookie
    Dec 21, 2004
    4,619
    Calgary Alberta
    Martin
    Should this not have gone into the "tech" section?
  5. ryalex
    Aug 6, 2003
    26,237
    Las Vegas, NV
    Ryan Alexander
    Actually, I think this is the appropriate thread to mention this problem my car is having. When I'm on the road and the engine is on, it keeps burning gas. It's gotten to the point where I have to fill it 2-3 times per week!
    I don't know what to do, really. I'm going to take it in for a service soon, maybe they can find the problem. I think it has something to do with that tube in the back where hot air blows out of the car when it's on. I suspect the gasoline is somehow evaporating and getting pushed out that hole.
  6. bert308
    bert308 Formula 3
    Nov 30, 2002
    1,776
    Roermond Netherlands
    Bert Kanters
    Luckily Ferraris have an automatic device that stops the engine when the tanks are empty, to prevent you from driving with no fuel which could seriously harm the engine and lead to $20000 repair bills.
  7. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    I can't find the fill location recommended for the Blinker Fluid. I think I am a little low since the windows are moving slower all the time. Does it go in the blinker itself, or is there a reservoir for it? Back to the original question. Maybe someone could come up with a direct injection brake rotor oiler, like the 2 cycle boat motor oil injection system. It seems like an awful waste to make the laborers work around all the wheels every time the car is washed to oil the rotors properly.
    BT
  8. pistole
    pistole Formula Junior
    Jan 31, 2005
    771
    Malaysia
    you guys are plain mean .......
  9. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    BTW when I first read the oil the rotors post I thought it was serious. I thought "Wow, that would make most brakes useless, but I guess high performance cars are different." I hope he is not wrapped around a tree with shiny rotors....
    BT
  10. dpospres
    dpospres Formula Junior
    Jun 29, 2005
    275
    Don't you think that you are all being kinda hard on the guy? WD 40 or 50W oil on the rotors??? Everyone here knows it is best to use synthetic 5w30 on the rotors!!! Com'on now!
  11. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    Now that's debatable. I swear by Redline 20w50 cuz it's thickerer but straight 60weight when on the track....
  12. taber
    taber Formula 3
    Mar 4, 2005
    1,582
    San Francisco
    Norman
    I can't buy anything!!!
    My torque converter is running low on torque, and I need more torque!!
  13. Dino Martini
    Dec 21, 2004
    4,619
    Calgary Alberta
    Martin
    What is Blinker Fluid?
  14. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,618
    Gates Mills, Ohio
    Jon
    It's the stuff that keeps the clicking noise up to spec.
    I usually change it when I'm changing my exhaust air freshener - just part of the normal maintenance routine.
  15. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,949
    wisconsin/chicago
    bo
    If you want to save a couple of bucks, just mix baking soda with each tank of gas...it will get rid of the smell almost immediately...
    Otherwise just jam 15-20 of those paper christmas tree freshners into your intake. Then remove the airfilter - its too restricting if used in combination with the freshner.
    These things will add 40-50 hp too...
    Further comment due to the society we live in, and at the advice of counsel: Note to anyone who would actually contemplate this. Do so at your own risk. And even then, you are a moron.
  16. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    The only proper way to prepare/wash a Ferrari for Concours is to completely replace ALL parts of your car, except of course for the chassis plate, with new, clean, unsued parts purchased directly from Ferrari. If you'd done it properly you wouldn't have this problem.
  17. Sfumato
    Nov 1, 2003
    10,194
    Angus Podgorney
    G0ddam Jim, I had Pebble beach LAWN tires, and SHOW tires. Doesn't everyone??
  18. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,842
    Jupiter, FL
    Paul Bianco
    after doing all the other stuff mentioned in this thread you might as well remember to change the air in the tires to fresh and newer air for a better ride! it also saves the life of the tires.
  19. Bullfighter
    Jan 26, 2005
    22,618
    Gates Mills, Ohio
    Jon
    G-d no.
  20. rcallahan
    rcallahan F1 Rookie
    Jul 15, 2002
    3,307
    Santa Barbara
    Bob Callahan
    If you use helium in your tires like I do, it handles much better and decreases th "unsprung" weight of the car!
  21. dpospres
    Jun 29, 2005
    275
    Atcually, I was in Autozone today and noticed that the blinker fluid was on sale. It is in the back, right next to the radiator caps for the old 911 Porsches.
  22. Air_Cooled_Nut
    Air_Cooled_Nut Formula Junior
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Let 'em try. They'd get laughed out of court.
    Seriously, now, the rust is 100% normal for STEEL rotors. If you don't like it then get the rotors cadmium plated (we do this in the VW scene). I would recommend against paint or powder coating as they can't take the heat -- ceramic coating would be best. Some grooving on the rotor face is natural and okay. You just don't want them to get really pronounced and sharp.
    If coating the rotors you don't coat the wheel mounting surface nor the brake face surface.
  23. avalys
    avalys Karting
    May 26, 2004
    181
    Colorado Springs
    Alex Valys
    Which reminds me, I saw an awesome gearshift knob for an Enzo the other day...
  24. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    Apparently the starter of this thread didn't think my sarcastic suggestion to oil the rotors was funny. I sincerely apologize for using my authority as a mod to spread such dangerous misinformation..........
    ........ Now if I could just stop freaking laughing :D :D Apparently he called his dealer to ask about oiling the rotors!!!! BWAHAHAHAHA I would have loved to have heard that conversation. No word yet if they told him the blinker fluid thing wasn't real.
  25. pistole
    Jan 31, 2005
    771
    Malaysia
    they are not made of steel.
