RV MIRROR | FerrariChat
RV MIRROR
Discussion in 'Technical Q&A' started by msdesignltd, Jan 3, 2006.
  1. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,566
    NYC. / E. Hampton
    Michael
    I Need to Remove and reposition the rearview interior Mirror on my 512 BBi.
    How do I lift the glued attatchment surface off of the interior windshield without cracking the glass.
    I Know!" Carefully!"
  2. RMDC
    RMDC Formula 3
    May 15, 2005
    1,005
    Boston, North Shore
    Have you tryed a heat gun - I have removed car dealer signs from rear of previous cars that way - as you said - carefully
  3. msdesignltd
    20,566
    NYC. / E. Hampton
    Michael
    I dont Think this is a heat related glue.
    It is like that clear thin Superglue.
    I am afraid the glass will come with it!
  4. 4redude
    4redude Formula Junior
    Jan 13, 2005
    733
    Fungus Corner
    Brian Keegan
    If it is a "Superglue" type of adhesive (can't remember the name of the specific chemical), use nail polish remover.
  5. hetek
    hetek Karting
    Aug 8, 2005
    141
    LI, NY
    I would call an auto glass shop like "Penn Glass" or "Triumph Auto Glass" or someone like that. They do this all the time when they replace windshields. I'm sure they all just don't bust 'em all off.
    Maybe they can recommend something.
  6. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    Would that be acetone? If you use that, make sure that you wear gloves and have lots of ventilation. We use to use that stuff to clean scuff marks off fiberglass sailboats. It works so good that it's scary. Acetone is so thin it appears to go right thourgh your skin. It can't be good for you.
    Bob Wassam
  7. Rickenbach
    Rickenbach F1 World Champ
    Nov 20, 2005
    11,297
    West
    Rickenhoser
    The adhesive is a vinyl. Use heat, just not too much. Either a lighter or small torch to localize the heat.
  8. Air_Cooled_Nut
    Air_Cooled_Nut Formula Junior
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Try using a razor blade style scraper, like what's used to scrape stickers from glass. Bump the blade into the bottom of the adhesive somewhat forcefully while applying an upward pressure on the mirror stem. This has worked for me with epoxy/glued and adhesive backed units.
  9. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    I think it is the same as mine, The gt4 uses a Carrello trapezoid shaped double adhesive pad. Exact same as on the 914 porsche and some old 911's. Alcohol and or heat will take it off unless it has been glued on. I pried on mine for hours and 2 drops of alcohol and it fell off. The pads have a tendency to come off on real hot days, never gets that hot here. If this is like yours hold the mirror up in the middle where you can see behind and have a friend mark the glass on the outside with a felt pen. Wipe off with alcohol glass and mount, apply the pad to the glass first, as the mount is hollow and if you put it on first you cannot burnish the entire pad to the glass, carefully apply the mount and press, not too hard I have heard of guys breaking the screen either removing or attaching the mirror!
    Good Luck
    Rob
  10. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Superglue has a Cyanide derivetive in it.
  11. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,471
    SFPD
    Dirty Harry
