I put goodridge SS hoses on my 308, and I, like others have a fitting that leaks. I have read about a copper sealing washer that cures this. Does anyone know if this is a part I can find locally or do I have to order it from a specialist? Anyone have a picture of one of these sealing washers ? thanks....
Measure the size required and check with a local industrial hydraulics shop. Or you can order from this place. Might have to buy far more then you need to make their minimum order but cheaper then having your brakes fail. http://www.metricmcc.com/catalog/Ch2/2-250.pdf
Before you try the washers just try to back out the fitting a few turns and then re-tighten. I found that the seat is the problem and if you torque down on the fitting it will reshape the seat/seal and the leak stops. Give it a try. Enjoy the ride
