Safely jacking up a TR | FerrariChat
Discussion in 'Boxers/TR/M' started by ozziindaus, Jul 11, 2015.
  1. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
    #1 ozziindaus, Jul 11, 2015
    Hi guys,
    I know this has been discussed in detail but I need some quick advice on how to safely jack the front of a TR up using 1 floor jack only (as pictured). Need to take the wheels off so i can start my brake caliper job.
    Floor Jack dimensions are (approximates):
    The length from the pads to the bar is about ~2 ft (60 cm), lowest height from ground to pads is ~5 inches (130 cm) and the span from pad to pad is from ~1.5 to 2 ft (45-60 cm).
    I think I can just get the jack underneath the front spoiler but I'll take it off if necessary. I also think the jack will end up around half way between the front spoiler to the wheel center.
    Can't find the jack points in the Owners or Work Shop Manuals and from what I've read, neither do I trust them.
    PS. Car in undrivable due to the clutch being out but can easily be pushed.
  2. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    I have the same jack setup you have but don't use it in the front. The jack points are aft of the front wheels and that setup won't get far enough back. Look under the car just behind the wheels and you will see where the factory jack goes. I don't use my original tools. I bought two scissors jacks at Walmart for ~$20.00 each and jack each side a small amount, alternating sides. It take about 2 minutes. Why don't you trust the jack points? They will support the weight you are jacking--just don't only use one side.
  3. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    Tim, you wouldn't believe it but that's exactly what I was thinking as son as I posted this thread up. Good idea.
    I read that using just one jack point was not a good idea. Your idea avoids the chassis twist and therefore risk of cracking the rear window.
    Thanks again.
  4. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    Sam .... we wrote a thread about it !!!
    Always two jacks in the front, one behid left wheel and the other ... :)
