safety belt question | FerrariChat
Discussion in '206/246' started by GermanDino, Oct 7, 2015.
  1. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    #1 GermanDino, Oct 7, 2015
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    I have never seen original Klippan bolts in any colour except for silver regardless of the type of car it was mounted too. Please do not take this as absolute but I would assume the bolt in your photo to be correct.
  3. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    05702 is a Feb '73 USA Dino with it as you show; silver/clear zinc colored Klippan 8.8 bolt and washer with gloss black metal webbing attach.
    A bit later than you asked, but all I have.
  4. Pantdino4
    Pantdino4 Karting
    Sep 17, 2015
    184
    Los Angeles
    Jim Oddie
    I suspect he means the metal tab, which is black and is held by the silver bolt.
    If you slide the webbing to one side do you see any evidence of the metal tab having been painted after the webbing was attached?
    If not I think it must have been painted before the webbing was attached, therefore original.
  5. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    yes, that`s what I think....
    it would be great if 1971/72 US-model 246 GT owner can have a look at their safety belts...
    for confirmation...
    it looks really odd, but maybe it`s original...
  6. ghenne
    ghenne Formula Junior
    Mar 8, 2004
    456
    Toronto, Canada
    #6 ghenne, Oct 8, 2015
  7. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    thank you George, very helpful
  8. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #8 synchro, Oct 8, 2015
    LHS: Feb '73 USA; gloss black web mounting tab, silver/clear Zinc Klippan bolt
    RHS: Oct '72 Euro; unpainted eb mounting tab, yellow Zinc/cad Klippan bolt
    Note that the mounting tab seems to be a different shape between Euro and USA
  9. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    thank you Scott, very interesting too
    my gloss black web mounting tab picture is from a Dino Feb. 1972....
    I thought the black must be original....
  10. rynoshark
    rynoshark Formula 3
    1,034
    Pacific Northwest
    The black coating on the ones I've seen appears to be more like a plastic coating than a paint. It has a thickness to it.
  11. Pantdino4
    Pantdino4 Karting
    Sep 17, 2015
    184
    Los Angeles
    Jim Oddie
    Is it just optical illusion, or is the bolt head larger on the US fitting? Is the thread the same?
    Jim
  12. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    I misunderstood the original question and would say that I have seen the mounting tabs in both painted metal as well as plated. I would think that either one is correct and I cannot offer any information as to which would be correct for what series, etc.
  13. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    looks like at least 1972/73 US-models had black mounting tabs ....
    most of the European markets never had black ones, maybe Switzerland/Sweden had?!
  14. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Focal distance with a shakey hand while trying to hold the US belt then use camera with the other one handed.
