Sagging door adjustment | FerrariChat
Discussion in 'Mondial' started by AndruL, Jul 6, 2020.
  1. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
  2. ronfrohock
    ronfrohock F1 Rookie
    3,940
    MA
    Ron Frohock
    AndruL likes this.
  3. JLF
    JLF Formula 3
    1,652
    AndruL likes this.
  4. theunissenguido
    theunissenguido Formula 3
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
    Thats not the right way to do this....should have forged the door upwards. You can do that with a jack when door is almost closed.
  5. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    Whatever works, but I wouldn't bring a floor jack to my car. The adjustment that I did worked for me.
  6. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    The way you did it has its limitations of course and is OK for very limited adjustment. Unfortunately it can cause issues with the door opening specifically on cabrio's that don't have the structural strength of the coupe. I performed the same adjustment to one of the doors of my cabrio, but wasn't able to open the door any longer when on a ramp (or even when the car is parked on an uneven spot) because the pin was positioned too high. No problem back on the flat floor, but you can still see that the door goes a tiny bit up when you close it and it makes more noise when closing because it's hitting the lock, really not ideal. I'm also in favor for the solution with a jack or press that forces the door up so that it's correctly positioned.
    Cadillacbart likes this.
