360 - Saving a Stradale | Page 3 | FerrariChat
360 Saving a Stradale
Discussion in '360/430' started by duck.co.za, Apr 20, 2022.
  1. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,770
    England
    Mark
    Nice find and sorry to see. The car is worse than it looks - I hope that someone doesn't get caught out.
    Senshi458 and duck.co.za like this.
  2. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,004
    Cape Town South Afri
    Dave
    That floor damage is worrying , big price . You hope it get's repaired not broken for spares . Although then it will have a story and be worthless :)
  3. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    I've seen 360s (when they where new and still valuable) get written off for much less intrusive damage. looks like major chassis floorpan damage which is a structural part of the car...
    I would only buy it for parts and at the price I've seen well used but non-crashed damaged examples so it's totally ridiculous imho..
    Sent from my CPH2145 using Tapatalk
  4. DutchFerrari
    DutchFerrari Formula Junior
    Apr 7, 2022
    769
    Bollenstreek - Netherlands
    Jeroen
    O yeah the price is absolutely rediculous, especially considering the floorpan damage, such a shame, if only it was like 40 to 50K then it would be worth it for someone with 2 right hands to restore it....
  5. duck.co.za
    Jan 9, 2007
    1,004
    Dave
    If you have missed my other thread "Making a Stradale lower dash" here is an update of the almost complete item in the car .
    So next is to fit the carbon door cards , fortunately I have one complete Stradale door with all its extended brackets for fitting the door cards and another damaged door that I will be able to salvage the mounting brackets from . I think it is sensible to fit the door cards and check all the clearances before committing to covering everything in Alcantara . Once that is confirmed correct , I will strip out the interior of most of it's wiring harnesses , as I need to replace the dash harness to CS RHD ( I have a LHD harness ) Then all the sound deadening removal and spray the correct statin black .
    360trev, 02360spider and RANDY6005 like this.
  6. Qavion
    Qavion F1 World Champ
    14,213
    Ian Riddell
    #57 Qavion, Apr 26, 2023
    I'm guessing you resolved the differences. I thought the F1 system had its own harness. Was one of those separately mounted high powered relays in your photos related to the air pump?
    duck.co.za likes this.
  7. duck.co.za
    Jan 9, 2007
    1,004
    Dave
    In fact I haven't , at that stage I was still driving on Modena harnesses. I think you maybe spot on , I hadn't even considered that the Jap cars had air pumps . I have not finished removing all the harnesses from the donor car . Which I must do!!
    Thanks for your reply
    Qavion likes this.
  8. duck.co.za
    Jan 9, 2007
    1,004
    Dave
    360trev, RANDY6005, Qavion and 2 others like this.
  9. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Use a hot air gun and it will peel right off...
    clean512 likes this.
  10. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,099
    Josh @jtcarprojects
    Looks great
  11. duck.co.za
    Jan 9, 2007
    1,004
    Dave
    Yes , you can see in the last pic I did a bit with a heat gun
    Apparently you can use dry ice and acetone !! and freeze it off , but I was worried how it would effect the rivets and glue , so heat gun is fine
    RANDY6005 likes this.
  12. Tbailey
    Tbailey Rookie
    Sep 26, 2021
    31
    Scottsdale az
    Todd bailey
    Trying to get in touch with you about flashing 360/430 gated computers
  13. Tbailey
    Tbailey Rookie
    Sep 26, 2021
    31
    Scottsdale az
    Todd bailey
    Trev what’s the country code
  14. duck.co.za
    Jan 9, 2007
    1,004
    Dave
  15. duck.co.za
    Jan 9, 2007
    1,004
    Dave
  16. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,099
    Josh @jtcarprojects
    Well done sir
  17. collegeboy
    collegeboy Formula 3
    Aug 25, 2007
    1,355
    Texas and Kaua’i
    Mikey
    Looks awesome man. keep it up.
  18. Lola360
    Lola360 Karting
    Oct 26, 2023
    130
    Bay Area, CA
    Connor
    Really cool project, thanks for sharing! Love this type of content.
  19. duck.co.za
    Jan 9, 2007
    1,004
    Dave
    Another update . Wiring harnesses !!!!!! I have removed the dash harness from the LHD Stradale donor ( for anyone who has done this , what a job !!!! )
    I have refitted all the harnesses I removed to paint the interior . The RHD Modena dash harness is still installed . I was considering just modifying this harness to move switches around ( would appreciate some feedback from guys who have done this , Josh did you do this ?) I know Randy indicated that he had changed all the harnesses ( Randy ? )
    So now I need to decided whether I attempt to swop out the dash harness , remembering that the harness I have is from a LHD car . Aldous thought that I may be able to flip it upside-down , which after looking at it may well be possible . The two round connectors in the trunk are not in the same place , but might be close enough .
    I would be interested in feed back if you have done this .
  20. duck.co.za
    Jan 9, 2007
    1,004
    Dave
    Aldous is correct !! I fitted the LHD dash harness effectively upside down and so far the only wire that needs adjusting is the heater/AC control ecu . I think I can strip the covering off the harness and move where the heater/AC ECU wiring come out the main harness . I have refitted the dash and lower dash to double check everything is good before I send it for covering . Image Unavailable, Please Login
  21. GogglesPisano
    GogglesPisano F1 Rookie
    3,159
    East Bay, California
    Joe
    I love little victories like that! Glad to see it still moving along.
  22. duck.co.za
    Jan 9, 2007
    1,004
    Dave
    Brake light pedal switch is different on the CS ( a four wire self adjusting switch ) I had to make a new bracket for it and then work out how the self adjusting ratchet worked . All seems good so far . It fired up first push of the button ( and the key does not activate the starter ) and the microswitch on the rear lid was preventing it going into gear . With that sorted it goes backwards and forwards .
    Interior pieces are sorted and ready to go to the upholsterer , for all new Alcantara .
    View attachment 3751264 View attachment 3751265
  23. Ferrari 360 CS
    Ferrari 360 CS F1 Veteran
    Dec 4, 2004
    6,884
    Cape Town,SA
    Jacques
    Well done! Looking forward to seeing this on the road!
