saving more weights | FerrariChat
saving more weights
Discussion in 'Technical Q&A' started by chinaboy, Aug 14, 2004.
  1. chinaboy
    chinaboy Karting
    Jan 26, 2004
    122
    Jardine Lookout, HK
    Eric Wong
    I recently find this products in car magazine (option fans, japan)
    wilwood forge calipers = 2.5 lb to 4 lb in weight
    in comparison, TOYOTA ALTEZZA / LEXUS IS200,
    a stock calipers weights= 15 lbs each!!
    wilwood brake disc(carbon-iron material)
    **size 330mm = 12 lb
    in comparison, TOYOTA ALTEZZA / LEXUS IS200 ,
    stock brake disc 290mm = 20 lb
    conclusion
    stock brake set= 35 lb X 4 = 140 lb
    wildwood brake set = 16 lb X 4 = 64 lb
    SAVES 76 lbs!!!
    and then we can use Forge Alloy Wheel (super light weight)
    **note: Japan technology, use 8000tons compression rate
    Japan currently has 70% of the market share in Forge Alloy Wheel
    **: F1 uses Forge Alloy Wheel (Enkei Japan)
    **: European factory has only developed technology at 5000-7000tons compression rate
    in comparison, a stock aluminium alloy wheel = 18,19,20inches size ….if changed to Forge Alloy Wheel, it can save 8.8lb each
    total: save 35 lb
    brake set + Forge Alloy Wheel= total save 111 lb per car.
  2. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,973
    MO
    Omar
    The question really becomes on of the quality of caliper and disk, as well as replacement cost.
