Scratched Inner Wheel Rim Cause? | FerrariChat
Discussion in 'F12/812' started by londonferrari, Jun 18, 2025.
  1. londonferrari
    londonferrari Karting
    Jun 2, 2024
    98
    London
    saul silver
    Guys, I just noticed this on my car. Is it possible that owning the car for a few months I didn't notice it, maybe given it's only visible depending on the position of the wheel. This scratch is inside the rim. To me, it looks like somebody removed a wheel balancing weight and scratched it. You can maybe see the remains of old adhesive. What do you guys think may have caused it? Thanks
  2. INRange
    INRange F1 World Champ
    12,563
    Virginia/Florida/Caymans
    JD
    I think you are right. Nothing on the car will cause that.
    londonferrari likes this.
  3. londonferrari
    Jun 2, 2024
    98
    London
    saul silver
    Previous owner had rear tires changed and because of the position of the wheel I didn't spot it before purchasing it. Shame on me. I really do check over cars, but admittedly I didn't have a look under the top of the rim.
    INRange likes this.
  4. INRange
    12,563
    JD
    Pretty sure it will clean up with some fine Emory cloth. You will probably end up doing the whole backside of the wheel to clean it up but it won't be a lot of work. As to whoever scratched it up trying to get the weights off......that person should never be allowed near any car.
    R J, Altoria F, dustywusty and 2 others like this.
  5. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,462
    Tampa FL
    100% when the tire shop guy changed the tires he used a flat head screw driver or knife like tool to scrape off the old wheel weights and so of the adhesive. Instead he needed to soak that area in GooGone or wd-40 and the adhesive would melt off. He 100% pried up the old weight with a metal flat tool instead of a plastic scrape/pry tool like used on upholstery.
    350MH83 likes this.
  6. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    Came here to say this. This is definitely done by somebody scratching an old wheel weight off the wheel with a sharp tool. I worked in a tire shop when I was a kid and worked with those idiots...
