430 - Scud F1 - Error Code - P1755 -Ignition Enabling Relay Driver | FerrariChat
430 Scud F1 - Error Code - P1755 -Ignition Enabling Relay Driver
Discussion in '360/430' started by rmarchjr, Jul 17, 2020.
  1. rmarchjr
    rmarchjr Formula Junior
    May 21, 2012
    576
    North east, USA
    Hello friends,
    Scud seems to be running well, but during routine maintenance I picked up the code above.
    It is listed in the F430 error code sheet but doesn't point me to any specific relay, sensor, or wire number.
    The car seems to be running, driving and shifting normally(no warnings) It may be shifting a bit slow...possibly not getting its ignition advance signal? Its hard to tell I been driving too many PDK cars lately.
    Anyone see this before? Any idea what sensor, wire or relay the code is referring to?
    Thanks!!
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    That point to the ignition relay ..probably was set either when you had a very low battery or a dead battery
    I would reset it and see if it returns
    Nothing to do with drivability .. if a problem with relay you would have a starting issue
    Sent from my moto g(7) using Tapatalk
  3. rmarchjr
    May 21, 2012
    576
    North east, USA
    Thank you Flash32! Finished the major, drove 20 miles and the code didn't come back. Time to put her on the Glen and run laps!!
