Scud hit 15k miles. 1000 miles per month average. | FerrariChat
Discussion in '360/430' started by datax, Dec 24, 2012.
  1. datax
    datax Karting
    Apr 9, 2006
    203
    VA (Washington DC)
    Ken T
    #1 datax, Dec 24, 2012
    I've been changing engine oil every 3500 miles and just flushed the gearbox and brake fluid. At 10k, lower control arm bushings were replaced as well as ball joints (the car drives like super tight and new after that, btw. Simply AMAZING!)
    Anything else I should do to keep this thing more fresh? Thanks gents. I'm driving the car about 1000 miles a month since I bought it. Thing is addicting to drive.
  2. Art138
    Art138 Formula 3
    Nov 22, 2007
    1,534
    Ft. Lauderdale
    How about the F 1 flush......?
  3. HKE46Boy
    HKE46Boy Formula Junior
    Jan 10, 2004
    310
    CA
    RENN Spec
    Factory or aftermarket bushings?
  4. Zxgarage
    Zxgarage Formula Junior
    638
    MD/ DC area
    Zack
    You are my hero...
  5. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    Ken the ball joints are monoballs, I bought spares from Ricambi (Hill Engineering) that are supposed to last longer, but I have yet to replace my OEM ones, after 14,000 miles. The passenger's side front LCA ball bearing is making some noises, so it is due for replacement.
    Some other tips:
    1) Add more insulation material on the following two sensors (driver's side axle):
    - E-Diff control valve
    - F1 solenoid
    2) contact Juri here in F-Chat, and get a F1 pump cooler
    3) The power steering and F1 pump fluid is long lasting, replacement should happen every 5 years or so, you can use Mobil 1 synthetic ps fluid. I have the specs somewhere, just not handy.
    4) Buy a spare set of the e-brake pads, they tend to wear out.
    5) I had a shop develop bigger cooling ducts for the engine, they are located underneath on the floor pan, ahead of the diffuser. This extra volume of air cools down the engine heads, and provides more fresh air to these 2 sensors, and the engine compartment temperature sensor (the one that displays the slow down warning).
    6) Crazy glue the balancing weights on the two front cooling fans. Once you lose them, there is a lot of vibration moved into the cabin, it gets worse the more balancing weights you lose. They get detached in warmer driving conditions.
    I will ad more as I go through my stuff.
    Car is super reliable, super fun, after almost 4 years with mine, it still is my favorite car. I have tested 3 458, MP4-12C, a LP640SV, multitude of VW, and nothing has come close to the feeling on my car. I'm awaiting for the next 458 track day car, but very likely it will be a little pricey, making an Aventador or CGT a better value (I prefer the CGT).
  6. vf430
    vf430 Formula Junior
    Dec 16, 2009
    666
    SoCal
    Good to know about reliability. I drove 3 k miles in past 3 months too. Plan to keep ths car for a long time. Driven everything out there , nothing screams buy me! Scud strikes a great balance.
  7. Afonsolaw
    Afonsolaw Formula 3
    Sep 11, 2011
    1,911
    New jersey
    The scud is calling my name!!!! I must have it!!!!
  8. rmani
    rmani F1 Veteran
    Nov 1, 2003
    7,334
    NJ
    RMani
    glad to hear you're getting full enjoyment out of your car!
  9. datax
    datax Karting
    Apr 9, 2006
    203
    VA (Washington DC)
    Ken T
    Bushings are factory but ball joints are from Hill Engineering.
    Shop recommends to change that and filter during next service so guess I'll do it in few months then.
    Thanks Rad. I'm gonna keep an eye on your tips. Cheers.
  10. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,204
    Beverly Hills, CA
    Jay
    Wait a second.... A Scud can exist for more than 10,000 miles? I thought they vanished into thin air
  11. Chiaroman
    Chiaroman Formula 3
    1,687
    New Jersey
    Always a pleasure to see someone driving their car.
    I've said it before that, "Life is too short...WAY too short".
    Enjoy it while you can.
  12. MikeR397
    MikeR397 Formula 3
    May 9, 2010
    1,469
    SE Michigan
    Happy to see you driving the car like it was intended. Just don't try too hard for perfection and enjoy!
