430 - Scud Ing Smart F1 relay - how many have it and is it worth it? | FerrariChat
430 Scud Ing Smart F1 relay - how many have it and is it worth it?
Discussion in '360/430' started by RRD, Apr 9, 2024.
  1. RRD
    RRD Rookie
    Mar 14, 2024
    13
    Rahul Ramesh Deshpande
    Hi guys,
    This is probably a great product based on past forum discussions, but how many of you have actually installed it and felt it proactively and accurately detected impending issues?
    I have a 2006 F430 (F1) with 15K miles on it and am thinking of getting it. I installed the Scud Ing E-diff bypass a couple of months back, mainly as a preventive measure to not have to deal with future E-diff issues and also get better hydraulic performance on the F1 pump. The car transformed for the better. Smoother shifts and ride for sure. So very happy with the product.
    I am on the fence on the smart relay though. Seems to me replacing my 50 amp F1 relay every couple of years should suffice vs putting the smart relay in. I also worry about false positives resulting in needless trips to the mechanic. I average about 1K miles a year (pure weekend pleasure road trips) and never track my car.
    Worth upgrading to the smart relay?
    Thanks for any insights!
    RRD.
  2. AandSC
    AandSC Formula Junior
    957
    Jax, FL
    Allen
    I’ve had mine installed for about four years and wouldn’t be without it. I like being able to monitor the F1 pump run time and I’ve had no false indications.
    colorfull and RRD like this.
  3. RRD
    RRD Rookie
    Mar 14, 2024
    13
    Thanks AandSC. Is the maintenance mode easy to configure? I imagine you need to set it up, especially for F1 maintenance like F1 fluid flush. Do you always set up maintenance mode during all services?
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    IMHO..both marketing gimmick..not necessary and just silly ..sorry just my opinion..one to cover up a problem that someone refuses to fix and the other a very expensive toy
    And that's coming from somebody who knows a little bit about the F1 and Ediff systems..,[emoji1]
    mwstewart and kestrou like this.
  5. RRD
    RRD Rookie
    Mar 14, 2024
    13
    Thanks for your frank opinion flash32. Care to elaborate? [emoji4] What is the problem getting covered up and which one is the expensive toy? Personally I liked how the car felt after installing the E- Diff bypass. And I don’t track the car so felt I don’t need the E- Diff anyways, so best to keep it disabled and have one less moving part in the system to worry about.
    flash32 likes this.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    I'll be more than happy to elaborate over the phone please send me a PM with your number and I'll call you like I said it's my opinion but an educated opinion
    RRD likes this.
  7. kestrou
    kestrou Formula 3
    1,527
    Danville, IL
    Kevin E. Stroud
    When f32 talks… I listen… closely! :)
    Kevin
    flash32 and RRD like this.
  8. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    I have it on mine. I just got the solid state relay for peice of mind
    Sent from my SM-S918U using Tapatalk
    vr4henry and RRD like this.
  9. GogglesPisano
    GogglesPisano F1 Rookie
    3,208
    East Bay, California
    Joe
    I have one on mine as well. Mainly for the reliability of the solid state relay. I wouldn't discount anything flash32 says either. He's very knowledgeable. Realistically, any issues could probably be staved off just by replacing the relay with a fresh one every so often. I just like gadgets. You'll get a ton of differing views on your ediff delete module. I have one I bought but never installed. I keep it on the shelf in case something fails and I need a quick work around until I get it repaired. Like what was mentioned, if you notice a difference by installing it, then something likely was not right and needed to be fixed.
    RRD and flash32 like this.
  10. RRD
    RRD Rookie
    Mar 14, 2024
    13
    Thank you so much flash32 for the long discussion today on all things F430! I really appreciate all the information on the F1 and E-Diff systems and also your guidance on general maintenance of the car, things to watch for, manifold options etc. Truly appreciate your patience with all my questions! I will keep you posted on the simple tests to guage the health of my F1 system.
    Best regards,
    RRD.
    flash32 likes this.
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    Truly my pleasure ! It was great speaking to you
    Sounds like you have a good mechanic
