Scud Ing Swiss DRL's installed on Scud - I love them... | FerrariChat
Discussion in '360/430' started by singletrack, Nov 4, 2014.
  1. singletrack
    singletrack F1 Veteran
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    Just installed these this evening. Very straight forward install; appears to be a very well engineered product.
    https://www.scuding.com/Shop/en/ilual-drl-solutions/69-ilual43-headlight-drl.html
    The difference is dramatic. These things are incredibly bright! So impressive I think I need to look at their tail solutions now as well. Basically you go from barely being able to see the DRLs, to them being as prominent as on any modern led-highlighted headlight. The pictures on their site are very accurate if not conservative.
    I will report back if I encounter any issues, but I'm very pleased so far. One thing I would mention is that there is a slight yellow to the led packaging which is transmitted out through the DRL light in direct sunlight/intense light. Of course, the leds themselves are a very pure white with no yellow tint and a very good match for the headlights. They are made with great precision (the contour; the backing plate) and slide into position with minimal dexterity.
    I'm going to drive around with these things on a lot I think...they definitely look cool IMO and they certainly increase the visibility of the Scud to other drivers. The latter is important - I think people miss the car from a distance because it is so low. I've had a couple instances of people looking *right over me*, then pulling out when I'm going 25-30mph.
    Fire away with questions!
  2. bart12
    bart12 Formula 3
    Nov 6, 2008
    1,711
    The River runs through it
    MD Leo
    How the install? Can you post it, I am not sure my gray matter maybe able to handle complex installation. Thanks>"
  3. RonnieRenaldi
    RonnieRenaldi F1 Rookie
    Aug 16, 2004
    2,686
    Look great!
    How long do you think for a pro/shop to install these?
  4. singletrack
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    They have a step-by-step on the site, but I was having issues linking to it directly. It's not bad at all, but I've done a lot of horrible lighting stuff in tight places, so YMMV.
    I give it a 2/10 difficulty unless you have massive hands or issues using them.
  5. singletrack
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    Thanks! I'll get some pics of my car at some point.
    With a floor jack and an airgun it took me about 45mins in no hurry. Pulled one front wheel, then the other. Anywhere from 30-60mins is reasonable IMO.
  6. singletrack
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    #7 singletrack, Nov 5, 2014
  7. enoyskt
    enoyskt Karting
    May 25, 2014
    50
    Cali
    S
    Any pics to see how it is in sunlight?
  8. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
  9. singletrack
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    Honestly they are the same. They are so bright that they cast light. It's Pittsburgh, so you might really wait for a shot in the sun ; )
  10. Forcefed
    Forcefed Karting
    Aug 14, 2009
    203
    United Arab Emirates
    Looks amazing. please post back if you encounter any misting or fogging/moisture of the headlights from the inside. Any fitment issues with the end plug, or does it go on tight?
  11. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I think they look awesome! I like it!
    I have Stef's complete LED tail light and LED 3rd brake light kit on my 360 and I love them.
    Super bright and excellent build quality. Stef makes top notch parts for Ferraris.
    Highly recommended.
    Dan
  12. F430giallomodena
    F430giallomodena Formula Junior
    Mar 2, 2012
    910
    Lugano, Switzerland
    my next buy :) love them.
  13. singletrack
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    No issues w fogging. I've already driven them in high humidity and rain.
    I already have the infamous scud headlight issues.
    Former is perfect. Just to slow feeding it in. You just press the end in as it is made of rubber. Seems like a nice solid connection.
