Scud rattling noise at high speed | FerrariChat
Discussion in '360/430' started by Scud36, Jan 20, 2012.
  1. Scud36
    Scud36 Rookie
    Jan 20, 2012
    5
    Hi, my scud with tubi exhaust has loud vibrating/rattling noise from rear right at highspeed, does anyone know what could be the reason?
    Thanks.
  2. rberg32
    rberg32 Karting
    Mar 14, 2007
    245
    Did you check all the exhaust brackets?
  3. Challengehauler
    Challengehauler Formula 3
    Jul 28, 2008
    1,315
    NE Connecticut
    DB
    Um....It's a stripped out street car that is by all means loud in every aspect.
    Duplicate noise caused by vibration in neutral by slowly climbing the rpm band by a couple hundred and holding for a moment. This will aid in pinpointing the sweet spot for the vibration.
    Most likely it is (as mentioned before by Rick) an exhaust bracket. Unfortunately (unless you have some very dedicated friends) no one will climb out of the car at "high speeds" to help.
  4. Scud36
    Scud36 Rookie
    Jan 20, 2012
    5
    Strange it is extra loud on hot days, at night/cooler weather, the vibration/rattling noise is not there. Perhaps the exhaust bracket, I'll check it out, thanks!
  5. Russell996
    Russell996 Formula 3
    Sep 24, 2010
    2,263
    New Forest UK
    Russell
    #5 Russell996, Jan 26, 2012
    Is it this style of exhaust?
    Unusually for a scud exhaust, the Tubi has flared tips that then go into the rear visible tips that are fixed to the car through the bumper, this gives the Tubi less clearance than normal. Worth checking how much clearance you have when stationary.
