Scud tires | FerrariChat
Scud tires
Discussion in '360/430' started by andybm3, Jun 7, 2015.
  1. andybm3
    andybm3 Karting
    237
    Andy
    Need to replace Scud tires and thought of going with MPSS 245/35 front and 295/35 rear - any thoughts from you experts out there? I shouldn't have issues going up in size?
  2. s.freid
    s.freid Karting
    Oct 7, 2014
    98
    Seattle / NYC
    Not sure about size but MPSS are great tires��
  3. roma1280
    roma1280 F1 Rookie
    4,833
    Palm Beach, Roma
    I have a scud and I don't think those are the standard sizes, maybe only out by 10 mm, but why would you want to get wider tires?
  4. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
  5. f355spider
    f355spider F1 World Champ
    18,044
    Are MPSS considered suitably high enough performance, or would one be expected to go with the Cup 2 which is their track tire version?
    Anyone used Bridgestone RE11?
    BTW, the previous owner of my car put 305s (Corsas) on the back of my car.....with stock size front...not sure of the logic of that, but will return it to stock 285s once they are worn...which should be end of summer if I drive it as much as anticipated. ;)
  6. Art138
    Art138 Formula 3
    Nov 22, 2007
    1,534
    Ft. Lauderdale
    I had RE-11s on my Scud. Great street tires and reasonably priced.
  7. Quilty
    Quilty Karting
    Mar 1, 2005
    199
    Pasadena, CA
    Christian
    I would stick with the stock size.
  8. ShineKen
    ShineKen F1 World Champ
    19,892
    Southern California
    Nostradamus
    Id go 305 rear
  9. f355spider
    18,044
    Why? I have 305 corsas on the rear of my car now. (installed by previous owner). Diameter is 1/2" smaller in diameter from the oem 285 size...and when worn, obviously even smaller. My local dealer had concerns with upsetting the traction control and possible brake wear with these non standard tires sizes. They recommended sticking with stock sizes. What do you folks think...valid concern?
  10. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    You do want the outer diameter of the tire to be close to the OEM specs. I can't remember what the particular numbers are, but I'm sure Taz could tell you. From what I understand, it will mess with the traction control as the computer expects to see particular numbers of revolutions but will see different numbers if the tire size is off.
  11. f355spider
    18,044
    #11 f355spider, Jun 10, 2015
    That was the concern my dealer expressed. They said under track conditions or "spirited driving" I could possibly see the traction control activated more frequently, and result in accelerated brake wear on the rear brakes.
  12. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    I suppose it would also affect performance as the TC would cut in more often and/or to a greater extent than it should.
