Scuderia Actual Weight, weight distribution and alignment | FerrariChat
Discussion in '360/430' started by F430GT, Apr 24, 2009.
  1. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    My friends at bbi AutoSport (Joey and Betim) did an amazing job with the alignment, corner weights and ride height.
    We lowered the car 1/2", and set the corner weights (13mm lower). The U.S. Scuderia rides 15mm lower than the European standard F430. The U.S. F430 ride height is so high, that it needs to be measured in feet.
    With 95 lbs of fuel, tools, fire extinguisher, stereo with subwoofer, the car hit the scales at 3,100 lbs even.
    Corner Weights: LF: 669#, RF 664#, LR 878#, RR 889# (before alignment and corner weight adjustments)
    Weight distribution: 43/57. Weight distribution with 180 lbs driver: 45/55. My old GT3 had an awkward 37/63 weight distribution, with my GT3 RS at 39/61.
    I later took the weight of tools (10.5#), fire extinguisher (8.5#) and the subwoofer box (8 lbs). I assume the stereo head unit is at least 2 lbs. Interesting fact, the subwoofer box seems to have two speakers, but it only has one, the other one is a cover with the shape of a speaker, removing it makes the stereo sound even worse.
    With no fuel, a base car (radio delete, no fire extinguisher, no tools) would hit the scales around 2,976 lbs. As a reference, my now gone 997 GT3 RS base weight with no fuel was 3,140 lbs, the same GT3 RS with PCCB (ceramic brakes) 3,100 lbs, the 997 GT2 3,160 lbs, the 997 GT3 3,185 lbs. All these Porsche numbers are actual (real) numbers for the U.S versions with no options and no fuel. The toolbox for all the Porsche GT3/GT2 cars weighs 8.5 lbs.
    The Scuderia is almost 200 lbs lighter than a 997 GT2, and the GT2 is already light compared to the Viper ACR, ZR-1, GTR, LP560-4, etc.
    The F430 Scuderia is very light. I think there is not a single production car with over 450 HP that hits the scales under 3,000 lbs.
    There are some additional weight reduction items to be considered:
    - Windshield liquid reservoir contains almost 15 lbs, I'm ok running this almost empty (although you get an annoying warning on the dashboard)
    - The stock wheels are not that heavy, but not light either. 25 lbs front and 28 lbs rear.
    - To pass sound regulations, the exhaust became bulky and heavy (over 40 lbs). It's quiet when you barely hit the throttle, regardless of RPM (nice feature), but once you get deeper on the gas, it opens the bypass flaps, and becomes loud, the sound is amazing inside, and even better outside.
    - The stock battery weighs 46 lbs
    Lighter wheels, battery, no windshield fluid, and a really light muffler can bring this car down to 2,850 lbs with a low fuel load.
    By the way we put -3.5 degrees of camber front and -3.0 rear, some toe-out front and stock toe-in rear, the car feels much nicer on the road than stock, and it performs quite well on my next door canyon road. This alignment is not recommended for street driving, but given that these car don't get driven that many miles, I really don't care about replacing tires every 2,000 miles or 10 years (whichever comes first)
  2. enzokidd
    enzokidd Formula Junior
    Jan 18, 2009
    727
    SoCal
    Shaunt
    very interesting info..thanks for the post
  3. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    Great post
  4. Senna1994
    Senna1994 F1 World Champ
    Nov 11, 2003
    13,187
    Orange County
    Anthony T
    Excellent.
  5. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    +1
    love the info, very well written!
  6. spyderman
    spyderman Formula 3
    1,622
    Toronto - Canada
    Spyderman
    Great information! Thank you for sharing!
  7. EVONick
    EVONick Formula Junior
    Oct 25, 2004
    314
    I weighed my US car as well when I first got it, 3150 with a full tank of gas. I have a late '08 car, so US CF package, fire extinguisher, lined trunk, full Alcantara interior, radio delete. The weight of gas is an unknown quantity if you want to be very very precise, but taking an average of what the gas I put in should weigh makes the car just under 3000lbs no gas. Deleting the fire ext, trunk lining, and adding Ferrari's CF sill and rear deck might get the car down to Ferrari's advertised 2975.
  8. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    Nick,
    Your car's weight is within specs. My car with a full tank of fuel would have been at 3,162 lbs. Your car has the alcantara package but no radio. Mine has the Alcantara package and radio, it is a 2009 so it comes with the carbon package (includes innner and outer door sills in CF). Removing the fuel from mine would take it down to 3,005 lbs. Removing the tools, radio and fire extinguisher, gets it down to 2,976 lbs. The alcantara option may be a little heavier than the standard (rather not pretty) fabric.
    I use the 6.25 lbs per gallon of fuel because that is what I have measured with fuel containers several times running my Porsche on track days, whether it's pump gas or 100 octane race gas. The F430 has a 25.1 gallons fuel tank.
    My GT3 RS user's manual reads 3,031 lbs, but the car was 110 lbs heavier than that with no fuel (3,140 lbs). Even after installing PCCB, it comes down to 3,100 lbs. The reality is that the 3,031 lbs weight is for the European GT3 RS with the CF bucket seats, Clubsport rollbar, no A/C, no radio, european bumpers and bumper frames, PCCB and no fuel, all these features can be added to a U.S. version GT3 RS at a cost close to $25k (including labor).
    One of these days I'm going to write a comparison between the GT3 RS and the F430 Scuderia. I just need to put more miles on the F430.
  9. Scuderia980
    Scuderia980 F1 Rookie
    Aug 12, 2006
    3,636
    Mountains--Colorado
    Dave S. V
    thanks for all the info...it really puts the factory claims in perspective.
  10. EVONick
    Oct 25, 2004
    314
    So basically our cars weigh the same, I also used that figure for fuel but went backwards with the calculation.
    And thus the radio system weighs 12lbs...
