458 - Scuderia Audio 458 Stealth Amplifier Sneak Peek | Page 3 | FerrariChat
458 Scuderia Audio 458 Stealth Amplifier Sneak Peek
Discussion in '458 Italia/488/F8' started by SoftwareDrone, Jun 25, 2021.
  1. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,539
    San Jose, California
    More details for anyone who is interested. The power cable from the amplifier connects to the positive post of the battery via a small ring terminal. Standard stuff. For the ground cable, if you remove the passenger side kick panel, you'll see that the negative battery cable is bolted to the chassis with a large ring terminal. This is the perfect place to ground the amp. I should have taken a picture of this but it slipped my mind. The attached images in this post shows where to connect a wire for the amp turn on. Very easy.
    The last image is basically my update on getting the harnesses ready for the larger, DSP amplifier version. I'm putting in the order today for some amp shelf brackets for the DSP amp.
  2. SoftwareDrone
    Jan 19, 2004
    7,539
    I've been working on SO many projects but finally had time to fully sort this one out.
    Now I can say I can offer a 100% plug and play DSP stealth amplifier kit for the Speciale. The amp mounts right above the battery, and the wires just plug right in.
    Every detail has been sorted out, from the correct lengths of the cables to the correct ring terminals and locations for the power, ground and amp turn on wires.
    You literally need two Allen wrenches and one Torx wrench to take the car apart, install this system, then put the car back together. The last Speciale I did took 30 minutes.
    Ferrari addict and SVCalifornia like this.
  3. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    Does it work on Italia also or only speciale?
  4. pnd4pnd
    pnd4pnd Karting
    116
    Los Gatos, CA
    Eric Thune
    Unfortunately not.
  5. SoftwareDrone
    Jan 19, 2004
    7,539
    For the 458/488/F8, I have developed some mini harnesses that bring the factory harness as close as possible to the custom harness.
    This video explains in more detail: https://youtu.be/B6dD9T-y4Oo
  6. jordanfsl
    jordanfsl Formula Junior
    Dec 11, 2010
    510
    Los Angeles
    Just curious, what is the difference between the 458 and Speciale in this case?
  7. Banzairacer
    Banzairacer Formula Junior
    482
    San Diego, CA
    Sanjeev Thohan
    I know it may be sacrilege, has anyone considered the kicker, etc lines of mini-amps some with DSP functions. it’s not quite audiophile quality but we are talking about 458/488 Ferrari's with substantive cabin noise.
  8. pnd4pnd
    pnd4pnd Karting
    116
    Los Gatos, CA
    Eric Thune
    the connectors
  9. SoftwareDrone
    Jan 19, 2004
    7,539
    My video explains this in detail.
