Scuderia Audio 612 Speaker Upgrade Project | FerrariChat
Discussion in '612/599' started by SoftwareDrone, Aug 26, 2021.
  1. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,861
    San Jose, California
    The 612 rear side panel speaker setup is tricky as they have some sort of tube that directs the sound to the surface of the actual panel for maximum efficiency. In order to mount a larger driver (in this case, a high end Morel carbon fiber 6 1/2" two way speaker), we have to design and 3D print an adapter plate as well as a larger tube.
    Here are some images of the preliminary design.
    brogenville and 599_GTO like this.
  2. SoftwareDrone
    Sponsor Owner
    Jan 19, 2004
    7,861
    The paper speakers are replaced with Morel high end carbon fiber 6 1/2 inch midrange/midbass drivers with silk domed 1 inch tweeters.
    The stock sheet metal sound tubes are replaced with thicker, 3D printed nylon tubes which are less prone to resonating.
    These pieces lock into 3D printed nylon adapter plates with gusseted mounting points to the car and brass threaded inserts for the drivers.
    Along with my Peerless (made in Germany) 13 inch subwoofer system, I honestly cannot imagine a way to get better sound out of a 612 Scaglietti.
    Makuono and brogenville like this.
