Scuderia CCB rotors weight | FerrariChat
Discussion in '360/430' started by jack, Nov 27, 2014.
  1. jack
    jack Formula Junior
    Nov 1, 2003
    269
    Switzerland
    Lionel
    This winter, I will refurbish my carbon ceramic brake discs (by SICOM). The front discs are cooked, but the rear-ones seem in pretty good shape. So how I can I determine the wear of my discs? It seems the weight is the only good way to evaluate the wearing!
    So does anybody know what's the "brand new" and minimal weight of the front and rear discs? It's probably without the central hat (please confirm).
  2. 93ls1rx7
    93ls1rx7 Rookie
    Nov 13, 2014
    18
    Micrometer. Weight isn't the best way, measuring the thickness is....
  3. Russell996
    Russell996 Formula 3
    Sep 24, 2010
    2,263
    New Forest UK
    Russell
    I understood weight is the official measure for the carbon rotors which is why they are all stamped with a weight when new. They need changing when the weight has dropped below a certain percentage of this new weight.
  4. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    I believe thickness is also stamped on the rotors. I agree that a micrometer measurement is the way to go. Seems silly to remove the rotors just to determine their wear.
  5. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,836
    Dallas Texas
    If you know you know
    CCB vs Steel rotor wear is measured differently. For example: CCB rotor " wear " is measured by time on the challenge cars.
    Steel rotor thickness is measured and I cannot tell you the last time I've replaced CCB on a street car " due to wear " .... So I confirm that spec tomorrow as needed.
    Jack, I'd suggest contacting the rotor manufacturer for their spec to be safe.
    S
  6. Russell996
    Sep 24, 2010
    2,263
    New Forest UK
    Russell
    My understanding is they aren't removed to weigh them but it is done by pulse induction - Ferrari dealers don't remove them to get the % and they don't use a micrometer!
  7. jack
    jack Formula Junior
    Nov 1, 2003
    269
    Switzerland
    Lionel
    I will look at them carefully a second time to see if there is some stamp or indication on them.
  8. scudF1
    scudF1 F1 Rookie
    2,917
    Long Island, NY
    Billy
    Btw. Why do they need to be replaced ? Do you track the car?
  9. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    The mode of wear is different to steel discs. The surface of the rotor actually disintegrates and falls away in chunks. The only way to properly measure the wear is to weigh them.
  10. jack
    jack Formula Junior
    Nov 1, 2003
    269
    Switzerland
    Lionel
    It's a Scud man! Of course I track it!
  11. scudF1
    scudF1 F1 Rookie
    2,917
    Long Island, NY
    Billy
    Lol. Good answer
  12. sunir
    sunir Formula Junior
    Oct 30, 2014
    758
    MD
    Sunir
    There are also some numbers markings on the carbon rotors
  13. jack
    jack Formula Junior
    Nov 1, 2003
    269
    Switzerland
    Lionel
    The only numbers on the hat are the minimum thickness : 33.5 mm and 35.5 mm. My discs are 34.06 mm and 36.05 mm thick! But according to the ECU, the front are 95% worn and visually they are cooked. The rear discs are like brand new. So no weight values?
  14. tazandjan
    39,188
    Put on a set of Mov'It CER rotors and pads and that will be the last set you need. Expensive, but permanent.
  15. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    Can you use Movit rotors with OEM calipers, or is it a package deal? Also, do you know what their rotors sell for ballpark?
  16. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Even when tracked? and is it warrantied?
  17. jack
    jack Formula Junior
    Nov 1, 2003
    269
    Switzerland
    Lionel
    No free lunch surely!
  18. tazandjan
    39,188
    Dave- Affirmative, Mov'It makes replacement rotors and pads for the OEM Brembo calipers after much prodding. Check with them for pricing.
    Do a search for results of track testing. 2500 or so miles of tracking required a front pad change with no measurable wear on the rotors.
    Warranty on brake parts for track use, right...
  19. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    Thanks, Terry. Good to know for future reference. Out of curiosity, why do you post to the 360/430 section? Not complaining, but it appears that you've never owned either car.
  20. tazandjan
    39,188
    Dave- Most of the things I post on are common to all the late model Ferraris. F1 of 360 is nearly identical to my 575M F1, battery recommendations are the same, brakes are similar and mine has Mov'It CERs. Not involved in prices and that kind of trivia, but I do have all the production figures for everything up to the 360.
    Plus there are over 35,000 360 and F430 variant owners, so way more traffic than we see in the V12 sections. I learn something every day over here.
  21. sunir
    Oct 30, 2014
    758
    MD
    Sunir
    ^^^ Terry great to have you here. Your posts are always informative and I learn something!
  22. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    Thanks. Curiosity satisfied. Also appreciate your insights.
  23. Living4life
    Living4life Formula Junior
    Jun 29, 2008
    263
    Only way to measure them is with weight.
    I've never seen a CCB rotor change thickness much. Beat or new ones still read about the same.
