Scuderia Hydraulic Pressure Range | FerrariChat
Discussion in '360/430' started by Animate, Aug 17, 2021.
  1. Animate
    Animate Formula Junior
    May 21, 2004
    275
    BC,Canada
    What is the F1 System pressure range for the Scud? I've seen 41bar-52bar for the 430. Is the scud the same?
  2. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    No, it is higher than the F430. From memory in SF2 mode it is 60 bar.
  3. Animate
    May 21, 2004
    275
    BC,Canada
    Thanks. I logged the pressure (with X431) and saw a peak of 69 bar.
    I presume the work shop manual lists normal pressure range. If anyone has access to that would you please post the spec when you're able. Cheers
  4. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    Standard mode (inc. 360 & F430): "The pump is activated when hydraulic pressure drops below 40 bar and is switched off when the pressure reaches 50 bar
    Scuderia: "when the Superfast shift mode is active: range 50 - 70 bar"
  5. Animate
    May 21, 2004
    275
    BC,Canada
    That's good to hear. That's the range I was seeing but was concerned it was too high. It was in superfast mode when I logged it.
