Scuderia radio options | FerrariChat
Discussion in '360/430' started by 1FAFP90, Apr 17, 2008.
  1. 1FAFP90
    1FAFP90 Karting
    Dec 13, 2006
    55
    I see two different radio options for the Scuderia:
    Radio / Nav / Bluetooth and Integrated Radio / CD / Bluetooth for an extra $3k. What is the difference between the two? Does either one have the subwoofer on the rear wall?
  2. ferrariKP
    ferrariKP F1 Rookie
    Jul 29, 2004
    3,994
    BKK/ LOS
    Kenny
    #2 ferrariKP, Apr 17, 2008
    Radio!?!...........Make sure you need one?
    Never turn it on, never. Its just like a usedless red box.
    Wanna rid of mine, if there will be no scar left.
  3. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    I went for the radio/iPod with subwoofer because stuck in traffic is stuck in traffic...
  4. 1FAFP90
    1FAFP90 Karting
    Dec 13, 2006
    55
    Which of the two radio options has the subwoofer? Or do they both? The iPod was a separate option.
  5. 483hp
    483hp Formula 3
    Aug 17, 2005
    1,428
    www.fca.alberta.com
    That's strange. On my Scuderia price list, there there isn't an option to add a nav. The "Integrated Radio/CD and Bluetooth system (BLUC)" is standard for North America. The F430 pricelist has two "radio" options priced $3K apart (BLUC and NAVC). The difference is the addition of the nav for the extra $3K. In both cases you get the center speaker pod.
    The nav option isn't what you would be used to (ie: there isn't a large LCD screen with a moving map). I think you'd be happier with a third party head unit with a flip up screen or a portable unit if you want a nav. If you browse the Scuderia pictures posted in this section, you will see that all Scuderia's delivered with factory radio's have the center speaker pod between the seats.
  6. marky1
    marky1 Formula 3
    1,130
    Mark
    Do you know what the sat nav is like - is there any screen at all? Cheers
  7. jeff
    jeff Formula 3
    Feb 19, 2001
    1,924
    North America
  8. MrTheKid
    MrTheKid Formula Junior
    Nov 11, 2007
    311
    CA
    Jonny Pickens
    i ordered mine w/o any radio only to get a fax from my dealer/ferrari NA that the radio was made 'standard' in all first Scuderias shipping to US/Ca
  9. 1FAFP90
    1FAFP90 Karting
    Dec 13, 2006
    55
  10. jeff
    jeff Formula 3
    Feb 19, 2001
    1,924
    North America
    #10 jeff, Apr 18, 2008
  11. 1FAFP90
    1FAFP90 Karting
    Dec 13, 2006
    55
    WOW! Your NAVC is more expensive than BLUC, while my list shows NAVC as no charge and BLUC as $3092. Too weird.
  12. 483hp
    483hp Formula 3
    Aug 17, 2005
    1,428
    www.fca.alberta.com
    I can't comment on the US options list, but here in Canada, there is only one choice: BLUC which is standard equipment. There isn't a NAVC on my options list.
    I assume that the NAVC is the new navigation head unit that started showing up in '07 F430's. If you do a search, you can find a thread with some pictures. Best to go to your local dealership and and have a look at a 430 with this option.
  13. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    Remove the air conditioning panel to gain access to the nuts securing the radio pod.
    To remove the speakers behind the seats, pry off the speaker grill with a screwdriver, remove the speaker from the housing, and unbolt the speaker housing. There are two slight indentations on the wall after the speaker is gone, but they are not noticeable since the material is dark. Use two plastic caps (available in hardware stores) to cover the screw holes on the wall.
  14. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    I went for BLUC and IPOD
  15. ferrariKP
    ferrariKP F1 Rookie
    Jul 29, 2004
    3,994
    BKK/ LOS
    Kenny
    Thanks Jack! I will think about it.
  16. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    #16 vm3, Apr 19, 2008
  17. ferrariKP
    ferrariKP F1 Rookie
    Jul 29, 2004
    3,994
    BKK/ LOS
    Kenny
    Looks FANTASTICO!!!
  18. 483hp
    483hp Formula 3
    Aug 17, 2005
    1,428
    www.fca.alberta.com
    Unlike the F430, the Scuderia does not have any speakers in the door panels of the base car. If you have a radio, you have the big boom box between the seats.
  19. Tarek K.
    Tarek K. F1 World Champ
    Sep 7, 2006
    10,789
    Cairo - Egypt
    Tarek K.
    I ordered BLUC in my Scuderia and got the radio with the subwoofer between the seats and two speakers below each side of the dash.
  20. Tarek K.
    Sep 7, 2006
    10,789
    Cairo - Egypt
    Tarek K.
    If you pick any radio option, the subwoofer between the seats will always be provided.
    If you don't want the subwoofer, you have to omit the radio option.
  21. 1FAFP90
    1FAFP90 Karting
    Dec 13, 2006
    55
    Thanks, Tarek. Radio is standard here
  22. Tarek K.
    Sep 7, 2006
    10,789
    Cairo - Egypt
    Tarek K.
    Don't mention it.......you'll get the subwoofer then.
  23. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    Don't know about the Scud's, but the stereo in the CS sounded terrible!
