Scuderia window closing question, | FerrariChat
Discussion in '360/430' started by ferrari360sp, Jan 21, 2013.
  1. ferrari360sp
    ferrari360sp Rookie
    Oct 23, 2012
    19
    I noticed last night that the window on the driver’s side takes approx. 10 seconds to close completely once the drivers door is closed. Is this a programming issue ???
  2. Art138
    Art138 Formula 3
    Nov 22, 2007
    1,539
    Ft. Lauderdale
    just tried: 3 seconds to go down all the way and 4 seconds up and then it backs-off an inch. Could be a sign that the regulator cable is binding on the protective sleeve it runs through. Suggest you take off the CF door panel and determine if the sleeve is cracked. BTW how many miles on the car??
  3. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    The window regulator isn't cable driven, it's a big metal arm with teeth at one end that is driven by a cog on the motor.
    This issue could be caused by either the exterior or interior door handle microswitch, or even the stop-switch on the regulator.
