Scuderia ? | FerrariChat
Scuderia ?
Discussion in '360/430' started by Oengus, Mar 18, 2024.
  1. Oengus
    Oengus F1 World Champ
    Has anyone ever experienced a power loss after start up for no reason?
    Attended a club event yesterday……car ran beautifully. On the way home we stopped about 3 minutes from my house for a quick green beer…..
    upon leaving it felt like I was running on 4 cylinders.
    thoughts?
  2. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,782
    Wait for the 'OK' message to disappear before starting it.
    The same thing happens if the battery voltage is low.
    LARRYH likes this.
  3. Oengus
    Got it….
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    If it does that, knock it off and then turn key on and wait until you get the ok message. If on starting you get an e diff or gearbox warning ( and others) you may have a battery on the way out. The volts are dropping too low due to starter motor load and this triggers silly alarms or it starts on 1 bank. On e bay you can buy a voltmeter that plugs into the power socket between the seats, useful to have in the glove compartment
    Oengus likes this.
  5. Oengus
    Just ordered one……thanks!
  6. Plainview
    Plainview Karting
    Aug 21, 2011
    95
    Dublin
    I had exactly the same happen to my Scud about six months ago. I thought it was badly broken. Shut it off, restarted it and it never happened again. They are just grumpy starters some times.
    robertjskelton, ShineKen and Oengus like this.
  7. ShineKen
    ShineKen F1 World Champ
    19,892
    Southern California
    Nostradamus
    Yep. It’s happened to me once. Just start it up again.
    Oengus likes this.
  8. Oengus
    My 550 would do it occasionally……only one bank would fire.
  9. Scottslaw
    Scottslaw Formula Junior
    I always give mine an extra half second or so after the "ok" symbol has illuminated, and it has never happened to me (at least not after I started doing this LOL! Gave me quite the scare the one time I jumped the gun. Yet another way these cars are not like "normal" cars (i.e., two banks run by two ecu's, running separate intake tracts, throttle bodies, maf sensors, etc...).
    LARRYH and Oengus like this.
  10. LARRYH
    LARRYH F1 Veteran
    9,679
    virginia usa
    the scud and others of that age require an EXCELLENT battery charge and following the startup procedure mentioned need an OK ... then it would start and be fine...I always keep mine on the battery tender when not driving
    Oengus likes this.
  11. Oengus
    Yes I do the same.
