seals solenoid valve from F1 box control | FerrariChat
Discussion in '360/430' started by concetti, Jun 18, 2019.
  1. concetti
    concetti Rookie
    Apr 10, 2018
    13
    CONCETTI Michel
  2. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    They're not available as spare parts. Just size them and replace with generic O-rings....
  3. concetti
    concetti Rookie
    Apr 10, 2018
    13
    CONCETTI Michel
    ok thanks you
  4. Jgivoo
    Jgivoo Formula Junior
    437
    New Jersey
    If you decide to replace the O rings, make sure they are made of material that withstands the properties of the F1 fluid.
    Give Magneti Marelli US division a call and see if they can help you. They should have a direct line with the main company.
    Tel +1 248-418-3000
    whatheheck likes this.
  5. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    The F1 fluid is just ATF so as long as the o-rings can withstand that they will be fine.
    There is a thread on here where this was covered in detail.
    I’ll see if I can find it and link it.
    The solenoid valves are actually supplied by Eaton.
  6. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
  7. vrsurgeon
    vrsurgeon F1 World Champ
    16,540
    Charleston, SC
    Curt
    I'd go to harbor freight and get those boxes of O-rings, throw them in some Power Steering fluid and see if they degrade.
  8. concetti
    concetti Rookie
    Apr 10, 2018
    13
    CONCETTI Michel
    ok i found it
    https://ferrarichat.com/forum/threads/355f1-solenoid.576140/page-3
