seam separation on spider top | FerrariChat
Discussion in '360/430' started by Steelton Keith, Jun 19, 2017.
  1. Steelton Keith
    Steelton Keith F1 Veteran
    7,803
    Raleigh NC
    Keith Hall
    #1 Steelton Keith, Jun 19, 2017
  2. Stout
    Stout Formula Junior
    May 9, 2013
    259
    Helotes, TX
    Victor
    Cannot tell where this seam is located. Can you get a better overall picture?
  3. Bigilo
    Bigilo Formula Junior
    Sep 28, 2013
    260
    San Antonio, Texas
    If this is on the rear "wings" they are kept taunt by the ecstatic bands that run through the top to keep the ribs folding back during the top going down. You should replace the elastic and that should fix the material from separating and pull the ribs back like they should.
  4. F-Serge
    F-Serge Formula 3
    Aug 3, 2004
    1,945
    UAE
    Serge
  5. Steelton Keith
    7,803
    Raleigh NC
    Keith Hall
    thanks everyone. will search more...i tried search function prior to posting this thread. will also try for better picture. I can see the elastic band.
  6. F5506M
    F5506M Formula Junior
    Nov 3, 2003
    922
    New Jersey
    Ray
    I had the same problem with my top last year, it was a snapped cable; the dealer fixed it for me. Seemed like an easy fix.
  7. Steelton Keith
    7,803
    Raleigh NC
    Keith Hall
    Yep. that's it. Thanks everybody. There is about a half inch play in the cable. Seems like it could be tightened somehow?
  8. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    The cable does not get stretched. It snaps. You can get a replacement from Ricambi if you want to DIY.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  9. gt1995
    gt1995 Formula Junior
    Sep 3, 2011
    498
    Rockville, MD
    That does. It agree with what I was told by the top convertible shop in the D.C. area. They said that mine has also stretched and they even tried to adjust it but there was not sufficient ability to tighten given the amount. I've not done anything about it in the 3 1/2 years I've had the car and it has caus d no issues, even in washing.
  10. Steelton Keith
    7,803
    Raleigh NC
    Keith Hall
    I've thought about just letting it go too...don't see any downside other than unsightly roof spine line. It seems as thought the designer of the cable provided for a tension tightening sleeve, but it seems to be locked tight.
  11. Bigilo
    Sep 28, 2013
    260
    San Antonio, Texas
    The cables are meant to keep the top aligned when retracting the top.I have seen pictures of other 360's tops damaged by the two sides not retracting at the same time. Be careful as repairing the top is expensive.
  12. mdslone
    mdslone Formula Junior
    Sep 8, 2016
    332
    South
    FerrariM
    I had what looks to be a similar issue several years ago with a 430. Dealer was able to fix it no problem. It was a cable if I remember right. I am looking back to try and find out
  13. Steelton Keith
    7,803
    Raleigh NC
    Keith Hall
    Bigilo. Thanks but don't worry. I have no mechanical skills whatsoever. I leave everything to the professionals. Thanks everyone for chiming in.
