searching toe-in adjustement value for the front wheel in degrees or arcmin | FerrariChat
Discussion in '206/246' started by chritin, Feb 16, 2024.
  1. chritin
    chritin Rookie
    Jul 12, 2007
    39
    france
    chritin regis
    Hello to all,
    I'm searching the toe-in adjustement value for the front wheel in degrees ?
    Thanks if you know this value
    Regis
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,201
    Norfolk - UK
    Tony
    The workshop guide and owners manual dont give those details, only measurements across the wheel rims.
    I had my car set up on a 4 wheel laser alignment machine many years ago and the total toe in was set at 0 deg 16' min (0.16) with zero steer (0.00)
    Car drives like a go kart and is very responsive.
    Hope this helps
    Tony
  3. chritin
    chritin Rookie
    Jul 12, 2007
    39
    france
    chritin regis
    Perfect !
    Thanks a lot Tony
  4. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,201
    Norfolk - UK
    Tony
    If you have your car set up by laser alignment then make sure the company dial in the right Dino spec. I noticed they had selected Dino 308GT4 and not the one underneath Dino 246.
  5. dm_n_stuff
    Dec 10, 2003
    43,648
    26.806311,-81.755805
    Dave M.
    not sure if this will help. Ferrari Tech bulletin on alignment settings for Dinos, among other cars.
  6. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,201
    Norfolk - UK
    Tony
    Thanks David, thats useful data.
    You can calculate the angle of toe in from that. Wheel dia is 392mm, toe in (mid) 1.5mm = 0.2166 deg or 13 arc minutes. or (min zero arc minutes to 26 am max
