seat belt light stays on | FerrariChat
Discussion in '348/355' started by Ferrari Girl, Jun 18, 2006.
  1. Ferrari Girl
    Ferrari Girl Rookie
    Jun 6, 2006
    41
    Rhode Island
    Erin
    Stays on constantly.....Any thoughts from the brotherhood would be helpful
  2. traimpz348
    traimpz348 Formula 3
    Apr 13, 2004
    1,568
    Avon,CT
    Matthew
    Mine for the driver always stays on too. I learned to ignore it.
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    That will happen if your mouse motor ECU's are disconnected; also if the sensor for the mouse motor position has gone bad...also if you buckle up with the seat-based back-up buckle rather than the mouse motor primary.
    I think, anyway. I've had my seatbelt bulbs disconnected for so long that my memory is a bit fuzzy here.
  4. fatbillybob
    Aug 10, 2002
    28,993
    socal
    Do you have mouse motors? If yes then do you motors work? If no they were disconnected most likely by the PO . Look under your seat for an open white two pin connetor. If you find one try shorting those terminals together and I bet your light goes off...or your car car is equiped with an ejector seat. So you may be pitched out of your car ala James Bond Goldfinger if you connect those wires together.
