Seat Belt Problem. | FerrariChat
Seat Belt Problem.
Discussion in '348/355' started by indytech, Jul 15, 2006.
  1. indytech
    indytech Guest
    May 24, 2006
    143
    Winchester Ca.
    Ken
    You know, I know this is hashed over and over.
    Does anyone know how to drive the mice to the rear of the track, and deactivate the automatic motion.
    I also would like to turn the seat belt warning lights off. Maybe jumper them or something. Something easy, hopefully. Thanks Indy
  2. Ricambi America
    Sponsor Owner
    1. To stop the mice, unplug the connectors under each seat
    2. To deactive the lights, remove the bulbs from the dash
  3. indytech
    indytech Guest
    May 24, 2006
    143
    Winchester Ca.
    Ken
    Thanks Jack. that sounds great. Tp tell you the truth I didn't know if it was a bulb or a an LED. I wasn't even sure it could be removed.
    I'm having a little trouble with my mouse on the drivers side. It seems to have a mind if it's own, and many times does not retract untill I hit a bump in the road or something.
    I guss I just need to figure out how to drive the mice back with the doors open, probably a switch or something.
    Thanks for the help. Best Regards Indy
  4. boulty
    boulty Rookie
    May 29, 2006
    25
    Essex, UK
    Andy Boulton
    I know this may sound ignorant, but not being the most mechanical minded.....what is a mouse and why would it need to be moved back??? Sorry to sound dumb!!!
  5. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    Try placing a bit of cheese at back of rail, this should make the mouse move back ;)
  6. tjacoby
    tjacoby F1 Rookie
    Nov 1, 2003
    2,857
    Vancouver Canada
    tj
    It was a US thing, even our Canadian cars didn't have to go that route. Imagine having a small rail along the door to automatically move a seatbelt from the front of the door to the rear of the door for Americans too lazy to connect it manually :D The right hand side of the belt was permanently attached.
    Fraught with problems apparently, I had to deal with some low-end rental cars that had them back in the era. Not the best use of government power.
