Seat potentiometer | FerrariChat
Seat potentiometer
Discussion in '348/355' started by Roger348, May 16, 2017.
  1. Roger348
    Roger348 Karting
    Feb 10, 2013
    104
    Reno, Nevada
    Roger Cody
    #1 Roger348, May 16, 2017
    Hello to all, I've pulled the passanger seat out of my wife's 96 F355 Spider and I see that the unit is together but it lacks the proper tension so as to turn the potentiometer. So my question is it ok to WELD TOGETHER THESE PARTS as I've read others do, or is there another way to resolve this issue, or better yet is there any aftermarket parts to repair/replace the potentiometer?
    Any and all help is most welcomed
    Cheers
    Roger
  2. greybeast
    greybeast Formula Junior
    Nov 15, 2011
    254
    Long Island
    Roger. I had a similar problem with my top / seats about 4 years ago. My pot was previously repaired with epoxy. i engineered a solution which I believe is permanent. i followed a previous thread (referenced in my post) for access, removal and electrical measurements, etc.
    I am not sure welding will help, as there needs to be some flexibility in the interface between the gear / ball and the clip. The pin I used forces the two pieces to rotate together while maintaining their ability to wiggle a little bit as the parts turn.
    More than 4 years later and countless top up / down cycles and there hasn't been a glitch with the repair (knock wood).
    Here you go:
    http://www.ferrarichat.com/forum/348-355-sponsored-bradan/400259-seat-potentiometer-repair-no-glue-pics.html
  3. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Great idea greybeast. I put it my saved folder!
  4. andrew911
    andrew911 F1 Rookie
    2,894
    Northern NJ
    Let us know how it goes Ernest!
