355 - Seats will not move | FerrariChat
355 Seats will not move
Discussion in '348/355' started by Pizanelli, Dec 14, 2022.
  1. Pizanelli
    Pizanelli Rookie
    Jun 29, 2022
    7
    Miami
    Guilherme Pizanelli
    Hi everyone. I have a question I removed my entire interior for leather repair and this week I started installation of the entire interior again I reinstalled the seats but both will not move back or fwd and before removing them they were working normal what do you guys think it could be just a reset if there is a reset way ?
    Thank you!
  2. Qavion
    Qavion F1 World Champ
    14,260
    Ian Riddell
    Are you talking about spider electrical seats?
  3. Pizanelli
    Pizanelli Rookie
    Jun 29, 2022
    7
    Miami
    Guilherme Pizanelli
  4. Qavion
    14,260
    Ian Riddell
    It seems unusual that both have stopped working. Perhaps something is out of sequence. Do they not work with the seat or the roof switches?
    Perhaps the 15 amp roof ECU fuse has blown? Power for the seat motors goes through the roof ECU. Do you know where the roof fuses are? (between the seat backs under the centre console upright section).
    There is an orange jumper wire under each seat. Make sure these are connected. I know they interfere with roof operation, but they might also interfere with seat operation.
    Also check the 10 amp AC System/Instrument fuse in the passenger footwell. These provide power to the seat switches and the roof switch. Usually there are a lot more indications that this has blown however (constant buzzing from the roof warning buzzer... and a lot of your instruments won't work)
    Carmellini likes this.
  5. Pizanelli
    Pizanelli Rookie
    Jun 29, 2022
    7
    Miami
    Guilherme Pizanelli
    Thank you very much will check all of that tonight and keep you posted, I noted that I have power to the switches all the back lighting comes on, I will check the fuses as you mentioned
    Again thank you very much for the help
  6. Pizanelli
    Pizanelli Rookie
    Jun 29, 2022
    7
    Miami
    Guilherme Pizanelli
    By the way the roof switch is not working also so it most be the fuses like you mentioned
    Will let you know
  7. Qavion
    14,260
    Ian Riddell
    If the roof/seat backlighting is working, it means that the AC/Instru fuse in the footwell is ok. That just leaves the 15amp fuse between the seats.
  8. Qavion
    14,260
    Ian Riddell
    The only other thing that I can think of are the seat potentiometers have been moved during the leather repair... but I didn't think this would affect manual seat operation.
  9. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    If you removed the tracks, it is possible to install them slightly cocked making the seats bind. Also use a light grease coat on the tracks.
    Qavion likes this.
  10. Pizanelli
    Pizanelli Rookie
    Jun 29, 2022
    7
    Miami
    Guilherme Pizanelli
  11. Pizanelli
    Pizanelli Rookie
    Jun 29, 2022
    7
    Miami
    Guilherme Pizanelli
    I want thank everyone here for the help with my F355 seats the fuses were the problem seats are operating normal
    Thanks again!! Cheers
    Qavion likes this.
  12. Qavion
    14,260
    Ian Riddell
    Interesting. I wonder why the fuse/fuses blew. Those fuses carry live battery power. I suppose something might have shorted out during seat removal if the battery cutoff switch wasn't used.
  13. Pizanelli
    Pizanelli Rookie
    Jun 29, 2022
    7
    Miami
    Guilherme Pizanelli
    The fuses were fine they were just not all the way in, I probably did that by removing everything else around during interior removal
    Qavion likes this.
