Second Gear experience? | FerrariChat
Discussion in '308/328' started by blockhead, Jun 1, 2009.
When is your 3x8 second gear available?
  1. Perfect, even when cold
  2. Useable very quickly (1-3 blocks)
  3. Takes a little time (0.5-2.0 miles)
  4. Grrrrrr I hate it!!!
Multiple votes are allowed.
Results are only viewable after voting.
  1. blockhead
    blockhead F1 Rookie
    Jan 21, 2008
    2,526
    rock {me} hard place
    knight who says "ni"
    What specific experiences do you have with 2nd gear in your 3x8?
    Mine WILL NOT shift AT ALL when cold for 1.5 miles;
    then it will begrudging will go into gear (no grinding),
    ...and then it will be perfect!
    I've tried every gear oil there is. I have learned to live with it.
  2. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    Mine will go into second with some effort but its not the snick, snick that I like once it warms up.
  3. rcm360
    rcm360 Formula Junior
    Nov 16, 2003
    343
    Kansas
    Reese
    How long do you let the car warm up before you start driving? Sounds like a synchro going out to me.
  4. blockhead
    blockhead F1 Rookie
    Jan 21, 2008
    2,526
    I warm it up a few minutes. It will not engage or grind until that "magic moment" that it just slips in... then all is well... :)
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    my 75 GT4 goes into 2nd even when cold. but my 328 takes 5 minutes.
    The GT4 makes up for it by leaking oil profusively under the car though.
  6. cockrill
    cockrill Formula 3
    Jan 23, 2008
    1,088
    Columbia, MO
    Jeremy Cockrill
    To my pleasant surprise, no issues with second gear with my new to me '84 Mondial.
  7. 348SStb
    348SStb F1 Rookie
    I think the 348 is just the worst. My Mondial t (and formerly my 348) would be unfit for second gear use for at least 10-15 minutes. I usually wait until the engine oil temperature gauge shows that the needle has risen to the first line.
    Recently, I drove a 3.2 Mondial and noticed that the 328/3.2 Mondial shifteris just so much better than the 348/Mondial shifter. Of course, Ferrari took a step backward when they went from mechanical linkage to cable linkage.
    My 512 TR was ready for 2nd gear in just about 3-4 minutes. Also mechanical linkage. (I know linkage probably has nothing to do with it, but I'm just noting it anyway.)
  8. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    My 1987 328 takes over 5 minutes in warm weather. It is also engine speed dependent. Higher engine speed reduces shifting effort.
  9. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    since I put redline in the tranny,no problems what so ever!
  10. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,608
    Gates Mills, Ohio
    Jon
    My neighboor's Daewoo Something-or-other has fluid second gear access after the ignition key is turned and after the car has sat outside all night.
    Back on topic, my 328 takes a few minutes in colder weather. As I posted elsewhere, in the 1986 R&T introduction test of the 328, the editors found that 2nd gear was unattainable for several minutes, so it's probably the nature of the beast.
    Gear oils have improved over the last 25 years, so the design flaws of Ferrari's old five speed can probably be ameliorated with the right lubricants.
  11. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Since I switched to Redline it goes into second immediately. Before the switch to Redline it would go into second after a very short time (perhaps half a mile) with relatively little effort.
  12. Easyrider7467
    Easyrider7467 Formula Junior
    Nov 3, 2005
    980
    Northen N.J.
    I'd say after I let the 328 warm up approx 5 minutes or a bit more, it will shift to 2nd. I usually drive out of my neighborhood, slowlyin first, and once at the main road its all gooood. Probably .05 - 1/10 a mile.
  13. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,518
    Canada
    Newman
    Goes in like butter stone cold, new syncros are the answer.
  14. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,284
    Illinois
    I put Redline NS in the gear case and it helped a lot. There was a big difference. Now I can get into 2nd within a few blocks of starting up. Then, it is all good.
  15. Drew_4RE
    Drew_4RE Formula 3
    Dec 19, 2005
    2,292
    FL
    Drew
    I've got redline in both my 328 and 348 and second gear is always smooth...
  16. rizzo308
    rizzo308 F1 Rookie
    BANNED Silver Subscribed
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    all good down here..... i have a new 2nd gear snycro + the new L/hand +R/hand ring nuts for the g/box shafts if anybody is rebuilding there gearbox.........
  17. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,257
    Indiana/North Carolina
    JIM
    My car will go into 2nd when cold, but it will chatter just a bit. Give it a block, maybe two (literally!) and it shifts smooth as silk! :)
    JIM
  18. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    #18 76Steel, Jun 1, 2009
    2 - 3 blocks and I'm good ...
  19. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    Like butter, really?
    I find these transmissions to be pretty notchy. Nothing like a modern transmission. After years of driving modern BMW's and other new imports, when I first got my Ferrari I brought her to my mechanic because I thought something was wrong. It got a green light from him and compliments from other ferrari guys who have driven her. However,I would never describe it like butter. It feels exactly like my old Z3 with the short shift kit on it...
    It certainly has nothing on that Ferrari Challenge Arcade game ;)
  20. Dr Tommy Cosgrove
    36,588
    Birmingham, AL
    Tommy
    Redline fixed mine
  21. Dr Tommy Cosgrove
    36,588
    Birmingham, AL
    Tommy
    ever driven an Alfa? ANY Alfa?
    crunch crunch crunch
  22. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    #22 JoeZaff, Jun 1, 2009
    I find the Ferrari engagement to be positive and direct. Before I got the Mondial, I always assumed shifting would be effortless. I have been repeatedly told that the tranny operates exactly as designed. That being said, they are just not the hot knife through butter feel I always imagined it would be. ...but boy do I love the snick snick sound.
    BTW, I used to have Lancias. My Zagato's shifter was this massive microphone looking job that had to be over two feet long, it was pretty effortless but vague as all hell. Of course, the linkage was complete crap. Driving cross country, the shifter fell limp in my hand. I drove 300 miles with only one gear---3rd. Eventually, we just gave up and put her on a U-haul. Of course, It couldn't climb the ramp unless we got a running start. We got up to 20 mph, climbed the ramp and locked the brakes. I was certain we were going to fly through the trucks cabin...Oh the joy of Italian cars.
  23. jsa330
    jsa330 F1 World Champ
    10,055
    75225
    Scott
    I always let my car warm up till the yellow light goes out, then go first-->third for a few minutes. Second doesn't become truly smooth and effortless until engine and oil temps are at full operating range.
    Same thing was true of my 330 2+2...19 years older than the 308, totally different engine and drive train.
  24. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    Same here. New synchros and smooth as silk.
  25. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    Can't find 'em?.. grind 'em!
