355 - Secondary Air Pump Project Part# 165903 | FerrariChat
355 Secondary Air Pump Project Part# 165903
Discussion in '348/355' started by paulchua, Sep 19, 2022.
  1. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,462
    Menlo Park, CA
    Paul Chua
    Greetings "Stooges"
    I'm starting a new project to repair/remediate the Secondary Air Pump Project Part# 165903
    Background.
    My Air Pump has stopped working and my friend @yelcab has a solution here that he was able to make work for the F355. I got the replacement part from him, and it was cheap at around $100. The problem is, that the area where it would need to be custom mounted is far too small to add it in. I might still go that route if this project fails, but I thought I would post here my journey for posterity.
    So, I just bought an old broken pump from my other friend Stefan from redbayparts (a site I highly recommend)
    What I'm going to do is take it apart and see if I can somehow install a new motor, or jury rig it somehow.
    By the way, it's a total PITA to take the pump out of a 456M - I'm taking it to a lift as there are 3 screws on the bottom mounting it to the chassis that I can't get out from the top.
    More to come.
  2. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,462
    Menlo Park, CA
    Paul Chua
    By the way, while I know this is just for emissions, I've read (not sure if true) that this may have detrimental effects on performance, definitely smog. I have a pesky check engine light code (bad o2 sensor passenger side) that I thought was related to a bad cat (could still be the case), I thought I might as well get this sorted first, and see what happens. If this works, my next step is to get the cat recorded (already have 2 brand new O2 sensors installed)
    If neither works, bad ECU?
    Cheers
