Secondary air pump | FerrariChat
Secondary air pump
Discussion in '348/355' started by GeorgeG, Aug 1, 2014.
  1. GeorgeG
    GeorgeG Karting
    Oct 3, 2012
    50
    Dublin, ohio
    George Gianakopoulos
    1998 355 6 speed has high pitch whistle/whine which lasts a few mins until car warms up. It is coming from the secondary air pump. Do I have to replace it?
  2. WATSON
    23,901
    WI
  3. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Thats a normal sound, the pump doing it's thing
    Just warming up your cats for you, tell it thank you :)
  4. Carlh94
    Carlh94 Rookie
    Sep 5, 2013
    24
    St. Charles, IL
    Carl Harris
    Does anyone have a photo of the location of the secondary air pump? Mine is a '99 Spider 6 speed!
    On my last emissions test the report stated "Secondary Air - N/A"
  5. GeorgeG
    GeorgeG Karting
    Oct 3, 2012
    50
    Dublin, ohio
    You can see it in the owners manuel in a schematic and on the Ricambi web site. By the way, Ricambi lists it for $1100
  6. GeorgeG
    GeorgeG Karting
    Oct 3, 2012
    50
    Dublin, ohio
    The high pitched whistle started happening at 31k miles. I bought the car 2 yrs ago with 24k. It only happens on a cold start. Car starts and runs normally.
  7. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    it is number 40 in this diagram...
    located under the battery charging points (RH engine bay)
    http://www.eurospares.co.uk/partTablePopUp.asp?ID=1680430
  8. ClydeM
    ClydeM F1 World Champ
    12,059
    Wayne, NJ
    Clyde E. McMurdy
    clean the cotton wadding & any other debris in it. That helped mine.
  9. ssnowball
    ssnowball Formula Junior
    296
    Scot
    Yup, the whine I experienced was taken care of with a thorough cleaning. A little tight to remove the pump, but not difficult. I would add that one the pump is removed, be careful with the plastic grid that wraps the filter, it can be brittle so make sure you remove all screws and gently remove it to prevent breakage, it's pricey.
  10. GeorgeG
    GeorgeG Karting
    Oct 3, 2012
    50
    Dublin, ohio
    Thank you!
  11. Carlh94
    Carlh94 Rookie
    Sep 5, 2013
    24
    St. Charles, IL
    Carl Harris
    Thanks guys
    I think a gentle clean of the pump is first. If that doesn't work then a more severe cleaning of my wallet! Just in case!!
  12. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #12 Dave rocks, Aug 13, 2014
  13. F1moving
    F1moving Formula Junior
    781
    BUCKeYe!
    Marcus
    Haaaaa, I thought that was my F1 pump as well!
  14. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Honolulu - Seattle - Okinawa
    Steve
    FYI - This pump runs on its own 15 amp fuse in the fuse box at the passengers feet. These very commonly blow fuses. Ferrari's cure was to swap a 20 amp fuse in. This pump was operating so close to 15 amp draw from the factory that as the pump ages it quickly draws more than 15.
    If you are blowing 20 amp fuses you need to change the filter material.
    All of these applied to my own 355 and putting in fresh filter material (generic, cut to fit) solved the problem of 20amp fuses blowing.
    Putting a fuse larger than 20amp is not a good idea as it will heat up and possible melt the fuse holder.
    My eventual solution will be to remove the whole damn system and kill the planet even faster.
