Secret code for alarm reset | FerrariChat
Discussion in '360/430' started by Sal Manzur, Oct 4, 2019.
  1. Sal Manzur
    Sal Manzur Formula Junior
    Sep 12, 2004
    291
    Upland Ca
    Salvador Manzur
    Where’s the secret code?
  2. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,741
    Just East of Weird
    Bob
    If you have the vehicle's documentation, it's on a card in an envelope. Also, there's a good chance that the dealer wrote it down on the inside of the owners manual
  3. Sal Manzur
    Sep 12, 2004
    291
    Upland Ca
    Salvador Manzur
    I looked through all the books/warranty card
    Radio reset codes ,etc. There is a little metal stamp with some numbers attached to one of the key ring. Could this be it?
  4. Bob in Texas
    Apr 23, 2012
    2,741
    Just East of Weird
    Bob
    Don't think so Sal. Best I know, it's on a card that was in a sealed envelope (well, sealed at one point in the past). Maybe some others will chime in.
  5. Sal Manzur
    Sep 12, 2004
    291
    Upland Ca
    Salvador Manzur
    Car came with two black key remotes
    And a red remote. Anyone know what the red one is for?
  6. f355spider
    f355spider F1 World Champ
    18,053
    The original selling dealer may also have this information in their records. If you call their service dept and show proof of ownership, they may assist you.
    I know my local dealer keeps this information. They also do so for their service customers. I bought a used 430 Scuderia, and during the first time I brought it in for service they suggested I share the alarm code and stereo code so they could add it to my customer profile.
  7. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Nothing now. It was the master and when used the first time it codes the PIN into the immobiliser. Now it’s just the same as the black ones....
    The metal tag is your key cutting code. The PIN is a 4 digit number.
    Skidkid likes this.
  8. Sal Manzur
    Sep 12, 2004
    291
    Upland Ca
    Salvador Manzur
    Thanks. Original dealer in New York.i am third owner. Will try them , have paperwork
  9. windsock
    windsock Formula 3
    1,160
    To reset the alarm you need the Red Fob and the pin. Missing either one means you are going to have issues. It either requires cloning fobs manually or replacing the alarm kit. Depending on the model of car that may also mean swapping the engine control units from LH to RH or replacing all together.
  10. tazandjan
    39,266
    Windsock- What is resetting the alarm? If he has three fobs and all three work, he is in good shape and better off than most. There are several folks now who can also pull his PIN code from his red fob.
    You really only need the PIN if your fob fails and you want to try keystrokes to get her started, or you need to program the Alarm ECU to accept a new set of three fobs. In the first case, just use one of the other fobs.
  11. Skidkid
    Skidkid F1 Veteran
    9,596
    Campbell, CA
    John Zornes
    Plus, the system will not accept the same code twice in a row so even if you put it into learning mode you can not program again with the same red fob. Once used It is no longer special.
  12. Sal Manzur
    Sep 12, 2004
    291
    Upland Ca
    Salvador Manzur
  13. Sal Manzur
    Sep 12, 2004
    291
    Upland Ca
    Salvador Manzur
    The car is beeping and flashing. Remote does not stop it. Won’t start.That is why I
    Am looking at resetting the alarm
  14. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Metal tag is key code for cutting physical key.
  15. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Either your fob is out of sync or the siren battery has failed. The fob is on a rolling code, so if you press it many many times, it might resync. If the siren battery has failed, it likely means the acid has leaked and compromised the circuit, so the only solution is to replace the siren.
  16. Sal Manzur
    Sep 12, 2004
    291
    Upland Ca
    Salvador Manzur
    Where is the siren battery!. Key or dashboard or engine?
  17. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,692
    South East
    Jimmie
    None of the above: the siren battery is in the siren - I cannot recall where it is in the 360 but multiple previous threads will probably tell/show
    As someone else has noted have you tried all three fobs ?
  18. mello
    mello F1 Veteran
    5,505
    CA Bay Area
    Steve
  19. Sal Manzur
    Sep 12, 2004
    291
    Upland Ca
    Salvador Manzur
    The car was raised at the body shop and the problem followed
  20. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,456
    On the Limit
    Dino
    Another nightmare imho issue. To be honest your best bet is to talk with 360Trev and delete it. It is made like crap and prone to failure.
    The PIN code is located in the car's documentation.. It is a square paper that has some perforations that allow you to open it.
    The alarm siren is located in the trunk on the driver's side. It is behind the panels.
    The immo, once it starts to fail causes a plethora of painful symptoms.
  21. Sal Manzur
    Sep 12, 2004
    291
    Upland Ca
    Salvador Manzur
    White envelope, second paper inside,with perforated edges,still unopened!. Inside a
    Four digit code!. Only perforated enough to
    Peak inside. However was not necessary as red remote did the trick and alarm disarmed and stopped beeping. All good once again in Ferrari land!. Thanks to everyone for their helpful comments
    Bob in Texas and f355spider like this.
