What is the bolt size and torque spec for these caliper mounting bolts: TAV 33, Loc: 13 Part: 117194 - Rear TAV 33, Loc: 19 Part: 117193 - Front The WSM seem to indicate both being 12x1.25 at 72 ft-lbs. But the actual bolt sizes are not the same. Image Unavailable, Please Login
they are in the technical specifications manual in the back. Dont lose the shims that go between the caliper and the hub. They center the brake disc in the slot. They can be a pain to get in. Use some superglue to tack them in place. The manual can be found on the web... or PM me your email and I can send you a copy . . Image Unavailable, Please Login
