Semi-Track 599 | FerrariChat
Semi-Track 599
Discussion in '612/599' started by GasAdams, Sep 4, 2021.
  1. GasAdams
    GasAdams Rookie
    Jun 17, 2020
    48
    Gas Adams
    Hi all,
    I want to take my 2007 599 GTB to the track a bit more. It keeps trying to kill me when I drive on the street...it's so fast! What would you do to make it a better, safer, more practical track car?
    I need to drive it there, so no slicks. It has a salvage title, though it is in perfect shape now. But, it will never be worth what an unbranded car would be...so I can do whatever I want to it without worrying about resale, etc.
    Thanks!
    Gas
  2. George Vosburgh
    George Vosburgh F1 Rookie
    I would go with a roll bar, they were made originally for the car so I'm sure you could get one. Stiffer sway bars, lower springs.
  3. tazandjan
    39,195
    Main thing is better brake fluid and swap it out before and after every track visit. Not a big deal with a power bleeder.
  4. white out
    white out Formula 3
    Mar 3, 2010
    1,289
    All new fluids and consumables and replacing any worn components would be a starting point.
    To get more out of the car: KW coilovers (corner balanced); wider front wheels; sticky tires (non-slick r-compound); heat management and weight reduction. Headers will get you a significant power bump.
    While not as good as CCB, converting to iron rotors (Giro Disc) would greatly reduce operating costs.
    George Vosburgh likes this.
  5. fatbillybob
    Aug 10, 2002
    29,070
    socal
    You could look at 599gto and copy some. If not...harness bar, race seat,6pt harness,200twr street tire,race brake pads, floating rotors if available, lowering on stock coils,corner balance,alignment for tracking,tune out some understeer,easy weight reduction...pass seat 50lbs...test for weak links?...motor temps?...trans temps?
  6. GasAdams
    GasAdams Rookie
    Jun 17, 2020
    48
    Gas Adams
    This is all excellent advice...thanks! I'm heading to the track this week. My brake fluid is relatively new, but I'm going to get a power bleeder. I think my tires will go in another trip, so I'll start digging into that with wider wheels and tires. I'll have to plan on the other changes a bit more. Thanks all.
