Senior Moment | FerrariChat
Senior Moment
Discussion in '360/430' started by English Rebel, Jun 6, 2014.
  1. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    I had another senior moment the other day. Was going to install the Scud Ing Swiss LED turn signal kit. So being a stickler for procedure I turned off the battery master. Opened the passenger door to remove the flasher relay and noticed the interior light was on. So was the luggage compartment light -- strange, maybe they bypass the battery switch. Replaced the relay and then went to remove the cover in the front wheel arch to swap the turn signal bulb. However I needed to turn the wheel to get to the cover so inserted ignition key and turned on to unlock the wheel and all of a sudden the warning lights and buzzers went crazy. WTF. Then noticed I still had my battery tender plugged in --- DUH, slap side of head with palm of hand. I guess my stickler for procedure took half a day off. :)
    Alan
  2. DrDon
    DrDon F1 Rookie
    3,627
    Infractionville
    Armando Decredenza
    Interesting.
    My take away is that using the battery tender and a really long extension cord, one can eliminate the battery to save weight!
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,543
    Charleston, SC
    Curt
    We've all been there Alan! :)
  4. C Alexander
    C Alexander Karting
    May 9, 2013
    190
    NY
    Mr. H
    On a somewhat related note, here is a pop quiz:
    Does anyone know what should happen if the car is running and the battery cutoff switch is opened?
  5. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    I haven't...
    lately!
  6. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    I'm not sure, but I'd worry about frying the alternator and/or sending a voltage spike through the sensitive and ultra expensive Ferrari electronics causing all sorts of consternation.
    On the other hand, perhaps nothing will happen. Please try it on your car and let us know the results. Thank you.
  7. Skidkid
    Skidkid F1 Veteran
    9,543
    Campbell, CA
    John Zornes
    I haven't looked at the wiring diagram but since it cuts the main battery connection I will make a guess. If the car is running and you disconnect the switch the car should keep running until you turn it off. Then it will be dead. Not sue I what would happen during a shutdown: will it store things correctly, will you get any V spikes, etc. As noted, I am not sure I would want to find out if there is a downside during shutdown but turning the switch shouldn't' produce an ill effect.
  8. C Alexander
    C Alexander Karting
    May 9, 2013
    190
    NY
    Mr. H
    I would never try it unless it was absolutely necessary. However, a few months back, the lock actuator on the passenger door malfunctioned, causing the alarm system to cycle the locks back and fourth to try and correct itself. Before I could realize what the issue was, I stepped out of the car while it was running and accidentally closed the door. It just so happened that the cycle stopped with the locks closed, locking me out...
    So, I thought I could at least turn the car off before having to deal with the situation and I turned the battery switch off, several times. Nothing happened at all...
    I believe if the car is running and the battery circuit is opened, the output of the alternator will keep the car's electrical systems up. Not a good idea but interesting nonetheless...
  9. DrDon
    DrDon F1 Rookie
    3,627
    Infractionville
    Armando Decredenza
    How did you get the bonnet open to turn off the switch?
    I was just thinking of the reverse scenario.
    i.e. I turn off the switch for a RESET or long sleep and then some helpful person closes the bonnet for me.
  10. C Alexander
    C Alexander Karting
    May 9, 2013
    190
    NY
    Mr. H
    The car had been sitting for a few weeks so I always made sure to leave it open in case the battery tender failed (which has happened to me before), in which case, I would have opted to turn the switch off and not allow the battery to drain.
  11. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    I would be more interested in how you could open the bonnet while driving the car to turn the switch off? :)
    Alan
  12. up4speed
    up4speed F1 Rookie
    3,694
    Long Island, NY
    Chris
    There is a pull cable under the dash to open the bonnet manually without power. There is also a pull cable under the gas lid to open the engine cover, and another cable in the engine compartment behind the drivers side tail light to open the gas lid. I think they covered the bases regarding opening the compartments in emergency/unusual circumstances.
  13. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    Hi - OK, sounds logical -------- but what do you pull if you can't open both the gas lid and the engine compartment ?
    Glass of Cabernet, please. :) Answer is: your hair :):)
    Cheers, Hank
  14. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    I was filling mine up the other day and looking at the pull handle to open the engine cover and was thinking the exact same thing -- how would you do it? Take of the under pan and somehow reach up to pull the gas lid release handle? Come on ensuring minds want to know. :)
    Alan
  15. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    It happens to the best of us Alan.
    Have a great Sunday.
    Dan
  16. up4speed
    up4speed F1 Rookie
    3,694
    Long Island, NY
    Chris
    I guess that would be the only way!
    I think the chance that being locked out of both would be very slim since the engine cover release is a mechanical release in the door jamb. I'm sure it's possible though, so if it happens, just start pulling your hair and hope that it opens for you! LOL
  17. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    I agree - a sudden change in load on the alternator by removing the battery risks a surge through the system. The risk is similar to disconnecting a good battery from the car after jump starting.
