Separate 308 engine from Transmission | FerrariChat
Discussion in 'Technical Q&A' started by lou staller, Dec 7, 2003.
  1. lou staller
    lou staller Formula Junior
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    My next major project is to separate the engine from the transmission from my 308 QV. The assembly is out of the car on a dolly. Do I have to remove the diff first? I haven't really looked at the assembly yet. I thought someone could help with some advice before I get into it. Thanks...
  2. ricrain
    ricrain Karting
    Nov 1, 2003
    213
    Dallas Area
    Ric
    The diff cover will hit the bottom of the rear head, unless you remove the studs. Normally, you'd separate the block and trans before you'd pull the diff cover. The block/trans can only be separated after you remove the transfer case, the bell housing and the rear main cover. Don't forget to remove the dipstick tube. In order to remove the transfer case, you'll need to ring nut tool for the lower transfer gear.
  3. lou staller
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    The engine is out of the car and sitting on a dolly. The clutch housing, transfer case, spacer and cylinder heads are all removed. It's virtually a bear short block still bolted to the transmission unit. After looking at the assembly this morning, while waiting for my car pool, I noticed under the 20 years of grease and grime 12 bolts running along the bottom of the block where it meets with the transmission. It looks like I might be able to separate the block from the transmission by removing those nuts. Can I? I would really like to not have to separate the diff from the tranny if I don't have to. Can I simply pull the block from the tranny without messing with the diff or tranny?
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Lou, reading carefully that's what Ric just said:
    The block does indeed come free of the tranny . Take a good look at the FPC & you'll see the block separated from the tranny in some of the views.
  5. lou staller
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    Thanks Ric and Verell. After having a closer look at it this morning it looks like a simple job. Couple nuts and some lifting power and it's apart. I'll do it this weekend. And the fun continues!
