Separating 308 water pump from the thermostat casting | FerrariChat
Discussion in 'Technical Q&A' started by NYCFERRARIS, May 26, 2020.
  1. NYCFERRARIS
    NYCFERRARIS Formula 3
    Mar 2, 2004
    1,011
    Hi,
    Replacing the WP on my 308 with a new one.
    I searched but surprisingly came up empty nothing is holding my 308QV WP to the casting except the gasket ( and likely some permatex) both are aluminum and I wanted to learn the best practice for separating these without damage.
    Also, need tips on safely removing the pulley w/o damage to the pulley.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    Correct, just the gasket … and a few m6 bolts. Remove all bolts, use a razor blade to insert between the housing and gasket. Create a gap, use a thicker wedge to make a bigger gap.
  3. NYCFERRARIS
    Mar 2, 2004
    1,011
    Thanks ! wanted to get a voice of experience before I went at the aluminum with a screw driver or blade or pryer -- any chemical to dissolve the gasket and cement overnight?
    Best way to pull off the pulley ?
  4. yelcab
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    No chemical will dissolve that asbestos gasket.
    thorn likes this.
  5. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Use a plastic scraper/spatula and force it into the gap.
  6. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,231
    Georgia
    Wade Williams
    Just beat on it until it calls a lawyer.
    2NA and tbakowsky like this.
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Depending on when it was last apart and by whom, a good careful whack might get it loose.
    Jdubbya likes this.
  8. absostone
    absostone F1 World Champ
    10,176
    After a small gap Wood shim your friend.
  9. tbakowsky
    Sep 18, 2002
    20,041
    The Cold North
    Tom
    Hit the seam where the pump bolts up to the housing with a dead blow hammer. She should come loose. However if the studs are corroded then some penatrant may be needed, but that is rather rare. All else fails, just drop it off a roof..should be good..;)
    brian.s and 2NA like this.
  10. NYCFERRARIS
    Mar 2, 2004
    1,011
    HOORAY! - the razor blade - increasing plastic wedge method worked like a charm - I got different size plastic wedges used for spacing and leveling floor tiling - ( real cheap) and it separated .
    Now to remove the bolt and pull the very expensive pully w/o damaging it -- anyone have a best method -- I don't have a hydraulic press but don't think I should need one with a good technique.
