Separating the transmission and engine on 308GT4 | FerrariChat
Discussion in 'Technical Q&A' started by skott308gt4, May 27, 2008.
  1. skott308gt4
    skott308gt4 Rookie
    May 27, 2008
    2
    Pasadena, CA
    Skott Jongeneel
    On the 308's the engine and transmission are connected together and I believe they share the oil between them. My machine shop has recommended that as I am rebuilding the engine and have them both pulled, I should have a bottom plate manufactured for the engine and the oil sump tube shortened so that the engine and transmission are separated but still sitting one on the other and then for later servicing of either the engine or the transmission only the assembly needing to be worked on needs to be pulled. Has anyone heard of this and how it worked out? Why did they attach the two in the first place? My only thought is that it may be to dissipate the heat of the engine better and that by separating them I may have overheating problems. Anybody have any information on this and its success or failure? Thanks.
    Skott
  2. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,311
    Seattle Area
    Dave
    While I'm certainly no expert, it seems to me the way Ferrari engineered it in the
    first place is the best way to go. The 'unintended consequences' of making such
    a major mod could potentially result in a destroyed gearbox and / or destroyed
    engine. I say leave it the way it was designed.
    Jedi
  3. 350HPMondial
    350HPMondial F1 Veteran
    5,334
    Edwardo
    #3 350HPMondial, May 27, 2008
    Scott,
    More then the connection plate will need to be reworked.
    First, have the drop gears re-engineered. $ 200.00
    Then have them machined. $ 2,000.00
    Then have the cover cut and welded. $ 300.00
    Then have the cover machined. $ 200.00
    Why would you want to do that?
    Edwardo
  4. Harry
    Harry Karting
    Nov 1, 2003
    101
    Germany
    Engine and transmission only share their oil if the shift shaft seal between the casings is worn out :)
    Regards
    Harry
  5. 412monzaindy
    412monzaindy Formula Junior
    Mar 8, 2005
    877
    Ontario Canada
    PBI
    Find another machine shop
  6. BigTex
    79,399
    Houston, Texas
    Bubba
    This is wrong..as noted it's two different oil systems entirely........
    Maybe you have a Miura also?? :D :D
    But the later Miuras have two oil systems also.....
  7. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    x10000
  8. BigTex
    79,399
    Houston, Texas
    Bubba
    Good thing you found us here on the chat!
    Welcome and if you have the Owner's Books it'll clearly answer your questions..there's lots of good Fcar shops in CA, but it appears this isn't one of them!!!
  9. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    There are some excellent line drawings of the engine and transmission assembly in the Workshop manual, see http://dino308gt4.com. And by all means show that to your machine shop, as you look for a new one :) As mentioned above, they only share oil if the shifter seal is gone.
    I assume they have seen that the crank goes below the bottom of the engine, so a simple plate won't do the job they suggest.
    Gerrit
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Here's what everyone familiar with the 308 is thinking when you're getting those reactions:
    The transaxle has the engine sump as a structural element to ensure that the engine, transmission, & bell housing are joined with the extremely precise tolerences needed to ensure proper mesh of the drop gears & rigidity for smooth power transfer.
    Pulling one w/o the other doesn't work either:
    There are a lot of fasteners that tie the engine & tranny together. Trying to separate the engine from the tranny inside the car would be a herculean task as you just can't get at a lot of things. Also, there is absolutely no way to drop the transmission in a 308, it has to come out the top.
    Not to mention that the engine or tranny will only get pulled 1-3 times during the car's life, so doing a lot of machining wouldn't make economic sense.
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,634
    San Carlos, CA
    Mitchell Le
    Wow, do these people actually charge for their opinions?
  12. skott308gt4
    skott308gt4 Rookie
    May 27, 2008
    2
    Pasadena, CA
    Skott Jongeneel
    I'd like to thank everybody for their input. I'm glad I found you guys here. Enough said, I see now very clearly what needs to be done and what does NOT need to be done.
    Cheers,
    Skott
