For Sale - Set of 12 Ferrari/Bosch CIS Fuel Injectors | FerrariChat
For Sale Set of 12 Ferrari/Bosch CIS Fuel Injectors
Discussion in 'Ferrari Parts & Collectibles' started by SeattleM5, May 1, 2022.
  1. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
    Selling a set of 12 perfectly balanced steel CIS fuel injectors (Ferrari part# 113975, Bosch part# 0437502010). As most are aware, the original steel versions are no longer available from Bosch (production ended in 2011) and the replacement is the brass version (Bosch 0437502047). I won't debate the merits of steel vs. brass as that has already been done on this forum. Having ultrasonically cleaned and bench tested hundreds of these injectors I can confirm that there are clear differences between the two types. After testing multiple injectors I have been able to put together a set of 12 that all have the same opening pressure. These have been ultrasonically cleaned and bench tested using a Bosch KDJE P400 injector tester. Opening pressures are all 3.4 bar, with no leak at 3.0 bar for 1 minute, and excellent spray pattern. These injectors fit the following Ferrari models: 308, 308 QV, 328, Mondial 8, Mondial QV, Mondial 3.2, 512 BBi, 400i, 412i, Testarossa. Given the number of injectors offered this set is intended for a V12 owner. I have a separate ad for a balanced set of 8 injectors for the 3x8/Mondial owners that might be interested.
    I'm selling this set for $480. Shipping is free (CONUS).
    George Vosburgh likes this.
  2. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Price drop to $430 with shipping included in Continental US
  3. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    Good price,, ✨✨
    GLWS Ferrari friend.
    Edwardo
  4. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Thanks Edwardo, hope you are doing well!
    Seems there's less interest in the steel injectors these days. In the past when I was able to put together a balanced set of 12 like this (which is not an easy task) they would get scooped right up. No big deal, they'll be available if anyone needs them.
    Sent from my SM-S901U using FerrariChat.com mobile app
    350HPMondial likes this.
  5. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
  6. mominayal
    mominayal Karting
    Feb 2, 2017
    119
    Indiana
    Will these work in a 456gt?
  7. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    I believe the 456 utilized the Bosch 5.2 Motronic engine management system and therefore requires electronic fuel injectors. These mechanical CIS injectors will not work for the 456.
  8. Boxer
    Boxer Rookie
    Jan 30, 2005
    7
    Still available?
  9. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Yes
  10. sherpa23
    sherpa23 F1 World Champ
    10,008
    Rocky Mountains
    Bastuna
  11. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    f355spider likes this.
