set or carb air injection plugs available | FerrariChat
Discussion in 'Technical Q&A' started by stacy, Nov 12, 2003.
  1. stacy
    stacy Karting
    Nov 2, 2003
    105
    halifax
    I recently removed the air injection system from my 308. I had the replacement plugs C&C machined from stainless with the proper nib on the end to prevent whistling from the exhaust. They are gorgeous.
    I have an extra set of eight plugs available. They are available for $100.00 plus shipping to anyone who wants them.
    Thanks,
    Stacy
  2. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Stacy,
    I'm interested in the plugs to do the same work this winter.
    Can you send/post a picture?
    Also, where did you get your specifications for the plugs?
    Do you have yours installed yet?
    And... Are you using washers as well when you install them?
    Thanks,
    --Mike
  3. stacy
    stacy Karting
    Nov 2, 2003
    105
    halifax
    I got the specs from S. Magnusen's article. Mine are in and they fit perfectly. I did use copper sealing washers that I bought from ferrari UK for a few cents each. You could probably re-use the ones that are already on your injectors. If you search the old archives you will find pictures of the plugs. They are exactly like the ones that others have had made. I will work on a digital pic but it wil take a few days. (I don't have a camera).
    A word of caution. It is an absolute pain in the ass to get the old injectors out of the front bank without removing the header or the engine. It is possible, and I will tell you how, but it is a ***** and requires destroying the air injection manifold (mine had a hole in it anyway).
  4. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Stacy,
    Plesae email me offline (click "Profile" under this post, then "Send Mike Procopio an Email").
    I'll be pulling the engine this winter for some gearbox work, so I figure then is a good time to get the plugs in :).
    Thanks,
    --Mike
  5. Steve Magnusson
    26,772
    stacy -- that's "S. Magnusson's" please ;)
    Mike P. (or anyone else) -- if you'd like a copy of the design/info send an email to me at [email protected]
  6. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Stacy,
    No need to worry about the digital pic.
    Do you have the part number handy for the copper washers from Ferrari UK?
  7. stacy
    stacy Karting
    Nov 2, 2003
    105
    halifax
    Steve,
    Sorry about the spelling error.
    Mike,
    The part number for the washers is 100511.
  8. stacy
    stacy Karting
    Nov 2, 2003
    105
    halifax
    Steve,
    Do you think it would be worthwhile posting your article and diagram in the parts & service section? Maybe there would be a copyright issue. Just a thought.
    S
  9. Steve Magnusson
    26,772
    I'll look into it Stacy (it would save me some work)...
  10. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    FYI, Ferrari UK does sell this washer... About $0.50 each. The part number is superceded by p/n <b>10280060</b>.
  11. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Hi All,
    I've investigated Stacy's plugs thoroughly, and they're solid. That said, I wanted to say that I haven't purchased these exhaust plugs and that they're still available.
    More information on the plugs (including info Steve M.'s excellent article on the subject) can be found in the FerrariChat archives.
    --Mike
  12. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,512
    Cape Canaveral/Atlanta
    Walt P
    I was unaware that there was a difference in carb over injected but if the plugs will fit my 1980 308GTSi , I will buy the off of you. I can be reached at 770-929-3685
  13. stacy
    stacy Karting
    Nov 2, 2003
    105
    halifax
    These plugs are no longer available
    Thanks,
    Stacy
