SETTING CURB IDLE ON '76 308 | FerrariChat
Discussion in '308/328' started by steve meltzer, Sep 4, 2024.
Tags:
  1. steve meltzer
    steve meltzer Formula 3
    Sep 18, 2004
    1,219
    with Enzo 8995
    1. Assuming that the carburetors have been synched on my euro '76 308, how do I set the final curb idle? There seems to be two adjustments that involve the cable and I can't figure out which one rules, or if one gets set before the other. I've enclosed pictures of the two adjusters that I believe set the curb idle. Adjusting the M8 nut (13mm wrench) that is forward most, and denoted w/a red arrow, does not seem to change anything. Is it the rear most adjustment that I have circled in red in my photo? Specifics would be greatly appreciated. Thanks, Steve.
  2. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    742
    Omaha, NE area, US
    Steve
    1) If you don't have a manual, you need one.
    2) Neither of the adjustments you highlight are what you are looking for. The throttle cable should be adjusted to have a small amount of slack when at idle.
    3) There are 2 idle speed screws (one for each cylinder bank) that need to be adjusted equally, and in very small increments. Both are on the left carbs, front and rear. I'll try to find a photo.
    4) If you don't know for sure the carbs have been properly synced, why would you assume so?
    steve meltzer likes this.
  3. Steve Magnusson
    BANNED Lifetime Rossa
    26,822
    Those adjustments are for minimizing the slack in the cable and the sheath -- not setting the idle RPM. There are screws on the carbs (on one carb in each bank IIRC) that set the resting position of the throttle plates on those carbs -- then the linkage between the two carbs on each bank sets the idle (airflow) of the other carb of each bank. You need a STE SK Syncrometer to measure the airflow in each barrel:
    https://www.amazon.com/Carburetor-Synchrometer-Weber-Dellorto-Mukuni/dp/B00SLH03R4
    steve meltzer and MaranelloMark like this.
  4. bitsobrits
    Nov 12, 2011
    742
    Omaha, NE area, US
    Steve
    Idle speed screws are A in this diagram. Again, these screws are only on the left two carbs, one on each bank.
  5. Dockboy
    Dockboy Formula Junior
    607
    Maryland
    Steve,
    The nut you indicate in the first photo is the lock down nut for the throttle cable adjustment. If you back the nut off, you can then rotate the cable housing ferrule to adjust the cable slack. You can also duplicate how the throttle linkage operates and is adjusted when you press the throttle peddle by tightening the ferrule housing simulating barely pressing the throttle peddle.
    If you didn't know this, there is no way your carbs are synced or your linkage is adjusted properly!
  6. Dockboy
    607
    Maryland
    MaranelloMark likes this.
  7. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    Thanks so much for all of the prompt and helpful input. A little history here might help a bit. I bought this car from Gooding/Driver Source where the carburetors had been set up about six months prior to my purchase. So I have had the car nearly 18 months or better with no problems whatsoever. Idled nicely at 1,000…right where I like it with A/C. This accounts for my assumption that the carburetors were synched, though I admit it was an assumption, and I did not know that with certainty.
    About six weeks ago, the car stumbled when pulling away from the light or a stop. It also seemed to be down on power, and it idled at about 750. I reasoned that the accelerator pumps might be performing poorly and perhaps the idle jets were dirty or clogged. So, I cleaned all those parts, and the accelerator pumps acted perfectly by just cleaning the nozzles. I did not replace the pumps per se.
    The car continues to idle at about 800 and I'd like to see it idle like it did before, at 1000. I admit in front of the entire peanut gallery that I was trying to take a shortcut to just bump the idle up a few hundred without going through a whole big to do. However, I was quite well aware I might get caught cheating. You nailed me trying to dodge a lot of work!
    I've read several articles (including Birdman’s excellent tutorial) about synching the carbs on this car and it looks like it may be beyond my capabilities, though I have an SK flow meter and have successfully set the carburetors on my Daytona and GTC.
    Thanx again. steve
    Sergio Tavares likes this.
  8. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    Did you high pressure air hose the idle jets clearly?
    They are big enough to get the bad boogger clog
  9. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    PS - All idle adjustments must be with no cable tension advancing to progression. Only idle please
  10. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    Yes, when I cleaned the jets, emulsion tubes, accelerator pump, etc. they were all cleaned in the ultrasound cleaner. They were blown out with a high-pressure hose. They were poked and prodded with diabetic needles that my cat loaned me, and I checked them to make sure light would pass through. I'm pretty sure they're clean.
    Always a cheater, this morning I turned both "throttle opening adjusting screws"; 1/8 of a turn CW. With the exception of one barrel, which read 5, all the others read 5 1/2 to 6 on my synchrometer. Yes, I know this is supposed to be done with all the linkage disconnected. However, once you do that, you still recheck them with the linkage in place. Getting the flow meter crammed in to read the forward most barrels did not instill great confidence, but I believe the readings are reasonably accurate. I will drive the car soon, but first must put the air cleaner back on, at least to some degree to see how she runs.Thanks again everyone for your help and comments. Steve
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,570
    San Carlos, CA
    Mitchell Le
    6 is too high at idle.
