Setting Ignition Timing on 246 DIno | FerrariChat
Discussion in '206/246' started by cjn944, Jan 17, 2005.
  1. cjn944
    cjn944 Rookie
    Apr 27, 2004
    11
    I have a 72 Dino that I am trying to set the ignition timing on. The distributer was just rebuilt with new weights and was then set up on that machine for the correct advance curve. The car is a Euro car with the 3 lobe distributer. The car currently has an MSD igniton with one set of points not both. (I was told that I did not need the second set of points.) Should the timing mark on the balancer line up with the 6 degree pointer mark when the engine is at idle. I have the timing light attached to the number 3 cylinder wire. I have the manual(its kind of vague) and I have been reading other posts here and am getting confused. Are there better setting than the stock settings. What is static timing? Any help is appreciated. Thanks Chris
  2. akydakyx
    akydakyx Karting
    Feb 9, 2002
    149
    Naples, FL
    Steve K
    join the fiat dino yahoo group. we have many guys who work on their own cars who can help you. unfortunately i am not one of them.
  3. cjn944
    cjn944 Rookie
    Apr 27, 2004
    11
    How would i join the Fiat dino yahoo group. I guess it would not matter its the same engine just in a different body. Should be same ignition timing, right?
  4. Steve Magnusson
    26,822
    When you say you have a "3 lobe distributer" does this mean the single point set opens and closes only 3 times per distributor shaft revolution? (I don't see how that could work on a 6-cylinder engine?)
  5. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    You do not need the second set of points with the MSD, what I did when I set mine up was set the motor (206) at 10btdc and watched the spark as I moved the distributor, pull the plug and very very slowly twist the distributor until the spark, lock it down and fire up the car and now use the timing light to properly set the timing, this method should get you close enough to start the car.
    The comment about joing the FIAT Dino Yahoo group is a good one if you want to work on your car yourself, they are the same motor. There is in the "files" section of the group a article reprint on installing a MSD ignition in a Ferrari, its a copy of some Ferrari article from long ago and quite good.
  6. Slim
    Slim Formula 3
    Oct 11, 2001
    1,735
    Pacifica, CA, USA
    richard
    I've never heard of a way to run the 3-lobe without both sets of points. There are dual-point cars where one set is used only at start up and these can be converted to single-points only but since you have the 3-lobe distributor, unless the MSD you have somehow can convert three triggers into six spark events, I don't know how the car will run without the other set of points.
    Otherwise, what you have said about timing light on #3 spark plug wire and the 6 degree mark are correct (though the manual might list an exact rpm for the timing check that may or maynot correspond to the rpm you have at idle).
  7. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    Well if Richard says it cant be done, I defer to him as so far in my experience he has not been wrong on these things.
    I have not just the MSD but also the optical pickup so no points on my 3 lobe distributor, maybe that is why mine is working. By the way that article I mentioned at the Yahoo group is on how to install the optical pickup and MSD, not just MSD.
  8. cjn944
    cjn944 Rookie
    Apr 27, 2004
    11
    I am still waiting to join the yahoo dino group. They are processing it now. If someone has the article could they post a link.
    Where do you get an optical trigger. If you put in an optical trigger you eliminate the points altogether, right. How does an optical trigger use the advance, is the mechanical advacne still used or is it all electronic. Is the optical trigger mounted in the distributer or on the balancer like American V8's.
    The car will start and run now with only the one set of points but it will not run smooth.
  9. cjn944
    cjn944 Rookie
    Apr 27, 2004
    11
    I have been doing some searching and was wondering if anyone has put one of those Petronix igniters in that replaces the points on the 246. Are there advantages to this over an optical pickup.
  10. cjn944
    cjn944 Rookie
    Apr 27, 2004
    11
    Now that i have had some time to do some reading I am thinking that I want to go to the Petronix or optical pickup instead of points. It seems alot easier than trying to mess with setting up two sets of points.
    Here is my question, which is better the crane optical trigger or the Petronix Ignitor. Any help is greatly appreciated.
  11. billb
    billb Formula Junior
    Jun 4, 2001
    407
    Shorewood, IL
    Bill Badurski
    The MSD needs one pulse per cylinder. A three-lobed cam using points will cause ignition timing fluctuations. If the optical setup has six slots, or whatever, that should work.
  12. Steve Magnusson
    26,822
    Can someone post a picture/drawing/sketch of the "3-lobe" distributor cam and/or a schematic of how the two point sets are wired together? Is there more "electronics" inside the distributor than just the bare point sets?
    Since the '72 246OMs show only a one-wire connection to the distributor (and only one active coil), I'm inclined to believe "You do not need the second set of points with the MSD" (i.e., each point set opens 6 times per distributor shaft revolution, and since the point set is only an event trigger with the MSD, rather than part of the high-current conduction path of the coil primary, all is OK.) -- but help me -- I want to learn!
  13. cjn944
    cjn944 Rookie
    Apr 27, 2004
    11
    I think I have decided to forget the points altogether if that is possible. Does anyone know if you can go to an optical trigger or to the Petronix and leave out the points. Is the optical trigger or petonix possible with the 3 lobe or is it only possible with the six lob cam.
  14. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    Can't post a link to the files section of the yahoo group since it would require your user/pass, I don't remember a "processing" time when I joined but it was a long time ago. If it takes too long, let me know in a PM and I will e-mail you the PDF.
    I have the Crane optical in my distributor, its a 3lobe and the optical wheel has 6 slots on it to cause the spark. It still uses the mechanical advance of the distributor. It was very easy to set up.
    No experiece with the Pertronix but should be the same
  15. cjn944
    cjn944 Rookie
    Apr 27, 2004
    11
    I joined the Fiat dino yahoo group and read through some of there post and the article on putting in optical trigger. There is alot of good information on that site.
    I decided to order the Crane optical trigger. I just called Summit Racing and order it today. I spoke with the tech rep at Crane and they said it would be fine to use the trigger with the MSD 6al box but i do not need to use the Crane amplifier box that comes with the kit. From what i heard the installation is easy. Now i just have to wait for the parts to come in. I think that this is much easier than trying to replace points adn now i will never have to replace the points ever again.
    If anyone else is interested in doing this this i can take pictures while i assembly it. If anyone needs the part numbers for the trigger kit let me know.
    I learned that you can put this optical trigger in and still run the original Dinoplex and it will work fine.
    Next, I would like to open up the Dinoplex and put the MSD ignition inside just to get the original look. It looks a little funny when you open up the trunk and see this bright red MSD ignition box. But that project is another day.
  16. dm_n_stuff
    Dec 10, 2003
    43,745
    26.806311,-81.755805
    Dave M.
    If you need a 6 lobe distributor, I have one that I'm no longer using.
    Went back to a Euro spec distributor and dual points.
    Solved some of my other problems pretty quick.
    So, if you want that 6 lobe job, let me know.
    DM
  17. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    Some people have had to use the amplifier to make the Tachometer work others (like me) have not, now this is for the earlier FIAT Dino so maybe the Ferrari Dino did not have that problem and also it was not a problem on the later FIAT's. Since yours is a 72 (and not FIAT) you probably will not have a problem but just FYI if your Tach does not work when you get it installed.
    Its easy to install all this stuff and with no more adjustment of points it makes maintenance a lot easier, even the timing seems to stay put.
  18. Steve Magnusson
    26,822
    DM -- Can you describe this system more? Do you have 2 active coils? Is/Are there one or two wire connections to the distributor?
  19. Reid
    Reid Karting
    May 18, 2018
    59
    Vancouver Canada
    Reid Fox
    I just finished rebuilding a Dino 3 lobe distributor. It has 3 lobes with a very wide crown on the lobes they stay open a long time. the 2 sets of points are set 15DEG from each other. When one set of points is at the center of the fully open the other set is at the center of fully closed. 3 lobes X 2 points = 6 firing events per revolution. You DO need both sets of points if you want to fire 6 cylinders. They work on piston pairs 1/5 4/3 and 2/6 are pairs, wen one is TDC compression its pair is TDC valve overlap. Here is when it gets interesting. I don't have a distributor machine. set both points to .025inch gap and install dist without upper caing in the way of setting points. Set crankshaft mark to 6deg 3/4 TDC (PM in Italian) (firing point) with cyl 3 at firing point compression and 4 at VO then adjust first set of points base to achieve points open event with testlight then lock down distributor and turn crank 1 revolution so that 4 is at 6BTDC firing then with the distributor locked adjust the second set of points base to achieve testlight open event. you now have points in phase with each other and gapped. Start engine and check with timing light. (Make sure mechanical advance isn't worn out either that what I had to repair)
    racerboy9 likes this.
  20. Reid
    Reid Karting
    May 18, 2018
    59
    Vancouver Canada
    Reid Fox
    also the distributor lobe has an event just before the points close it opens slightly wider, don't set point gap there set it in the middle of the lobe, I figure the slight wider opening is taking place when the opposite points open (firing event) to help prevent arcing on the open points
  21. Ken Ivey
    Ken Ivey Formula Junior
    256
    Portland, OR, USA
    Ken Ivey
    Here’s my understanding…
    Yes, you need both sets of points. Distributors are geared to revolve at 1/2 the crank shaft speed – you get 3 sparks per engine revolution. Each point fires every other spark plug. I believe they used the 3 lobe/2 points to reduce point hop.
    Later distributors had 6 lobes and 2 points. But only one set of points operated at a time. For pollution purposes - at lower RPMs a switch would go from one set to the other to change the advance.
    Ford did use a distributor with two sets of points in their performance engines to get 2 sparks per cylinder, but that’s not the case here.
    Ken
  22. Reid
    Reid Karting
    May 18, 2018
    59
    Vancouver Canada
    Reid Fox
    Thanks for the info I have also seen some early dual point systems that use 2 sets of points to expand the dwell by making a longer points closed duration by making the first set close first and the second set open last
