Setting valve installation height? | FerrariChat
Discussion in 'Technical Q&A' started by Dave rocks, May 13, 2016.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #1 Dave rocks, May 13, 2016
    Hello Folks,
    For probably about a year now, I've been trying to find (get pictures) of the process and tools used to set valve height - especially on the side intake (compound angle) valves of the 355 and 360.
    After grinding / dressing the seats and installing new valves, I fully understand the need to set the install height by grinding the valve tip. This image is from the WSM and I understand this in theory but I struggle to understand this on the side intake valves at compound angles.
    Anyone have photos to share?
    Thanks in advance :)
  2. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    My understanding of it is that you are measuring the distance from the cam base circle face to the valve stem. You should be able to verify the distance from the cam to the valve stem tip with the cam lobe facing away from the valve stem. I think there is a Ferrari tool that mimics the diameter of the cam and holds the dial indicator and you set this tool into the cam journal in the head to measure this.
  3. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hello Hal,
    Well, I understand the theory of that but I have yet to see anyone post photos of it - allow me to explain:
    On the exhaust valves and center intake valves, the cam center line is perpendicular to the valve axis center line. So, when installing those and using the tool, the only variable is the rotation of the tool and indicator about the cam center line (sweeping of the indicator). But, on the side intake valves (at compound angles), you need to deal with two degrees of freedom: 1) Sweeping the tool (indicator) and the in and out motion (co linear) to the cam center line and trying to line up the indicator tip (probe, which should come to a point) with the dead center of the valve tip. I'm not understanding how this will be done with a level of accuracy.
  4. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    I don't know anything about 355/360 heads, but I made a tool similar to the Ferrari tool for my 308 by turning down a piece of aluminum stock to the exact diameter of the cam bearings, then cross-drilled it to receive a dial indicator.
    When fitting the valves we installed a valve, along with it's bucket and a "reference" shim. then we put the cam on and measured the clearance. We ground the valve stem to bring the gap into spec.
    Then we removed the cam and used the tool to measure the distance to the valve/bucket/shim. Using the reference shim allowed us a bigger landing area for the probe, which we rotated to get the minimum value. We now had a reference. Then for each subsequent valve we installed the valve/bucket for that cylinder along with the reference shim, measured the distance and ground the valve stem as needed.
    Note that we used the bucket for that valve (along with the reference shim) for each subsequent valve. We suspected that there might be some difference in the machining of each bucket, so we did our measurements with the bucket matched to that valve. We assembled the heads with the valve/bucket set matched to each valve.
    I realize the 355/360 valve arrangement is different and much more complex than the 308. Hopefully the procedure I explained will give you some ideas.
  5. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    from an engineering perspective, that offset wouldn't have much of an effect on what you are trying to get with this measurement as long as the valve end is ground square to the valve stem.
    The validation of the location of the end of the valve is to ensure you are still in the tolerance range for the motion of the valve bucket. You adjust the valve shims on the buckets for the fine adjustment when you shim the valves and then adjust the cam timing.
  6. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,424
    Dumpster Fire #31
    SMG
  7. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hal, the 355 has hydraulic lifters and no shims.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thank you and while I can appreciate that tool, with respect, I don't feel that's the correct tool to use give the specification of the WSM. From an engineering standpoint, relationship of the valve tip to the cam is the critical measurement for proper motion with the lifter. The relationship of the valve tip (or key grooves) to the spring seat will influence the spring load. The spring seat surface may be a much more loose tolerance.
  9. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Considering that Ferrari has used this identical methodology for the last five decades, I would expect that most specialists and Ferrari-centric machine shops have the "tool" which is basically a length of rod stock with a couple of holes drilled in it. Other than the dial indicators, the tools are less than $10 to make. I can't think of a DOHC Ferrari engine that does specify the installed height as referenced from the base circle of the cam.
    The WSM diagram shows "the tool" and the tool in use.
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I'd submit that the tool costs a tad more than $10.00 to make give that the OD needs to be precision.
    And yet it does not show the tool used on the side intake valves and the fact that what I've explained above won't be easy to accomplish. Certainly if it is so often used and easy to do, I'd expect to easily obtain photos of an example :)
  11. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    Ah,..
    From an engineering perspective the same idea still applies. You are trying to hit the center of the adjustment range so that the tappet (hydraulic or solid with shims) is close to the middle of the range and prevent the tappet from bottoming out when cold. There is the same check on a solid lifter car like the 328 with the same .012" tolerance range.
    The slight offset of the cam to the centerline of the valve doesnt affect that measurement much. Think of a triangle with a long side and a short side. Changing the short side length slightly has very little effect on the lengths of the long side and hypotenuse. I doubt you will get more than .002/.003 across the end of the stem if you swept the indicator.
  12. tbakowsky
    Sep 18, 2002
    20,021
    The Cold North
    Tom
    Dave, with all due respect, I think your over thinking this one. Do it a described and you should be fine.
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #13 Dave rocks, May 13, 2016
    Hello Hal,
    Yes, you are correct that the specification is .3mm (.012" inches).
    But, take a look at this layout I just did. I have a camshaft at my shop and just measured the side intake lobe angle with an optical comparator and it's 3.5 degrees. The vertical difference along the 6mm valve stem length is .014" so that's .002" more than the allowable specification.
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Howie, I overthink everything so I fully understand the proper methods :) - See the layout I just posted, I think that may support my thinking on this one :)
  15. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    youre looking at it wrong. The measurement zero point is the center line of the cam or an inch or so above the valve stem end. Swing an arc from the center of the cam and see what you get side to side on that valve stem. (The end of the stem should be much better that 3.5 degrees from flat also )
    If you measure it the way that Ferrari recommends... it is not nearly as sensitive to where you are measuring on the end of the stem.
    if i get a chance later I'll sketch it up for you.
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hal, I don't understand your reply at all - yes, please sketch it up.
    PS, the layout I did is looking at the cam lobe from the side which equates the the angle of the valve tip as installed which is why I stated earlier that the tool would be very hard to use in the degree of freedom of in and out about the cam center line.
  17. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #17 Dave rocks, May 13, 2016
  18. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    You're not understanding how installed height is measured. The lobe has nothing to do with anything.
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The lobe of the cam is perpendicular to the axis of the valve. It was alot easier to put the camshaft on the comparator and measure the angle then cut the head down the center line of the valve to measure the valve angle.
    That was the only point of mentioning the cam lobe which I thought was clear in the layout(s)
  20. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,424
    Dumpster Fire #31
    SMG
    More then one way to skin the proverbial cat, the reference from the spring seat is just as accurate as the spring seat pressure is based on the valve seat to keeper groove distance. As the seat wears the spring pressure will change. I'd have to look but all the WSM give an installed height for the spring, with that data it's not hard to calc' the wear of the seat.
  21. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,424
    Dumpster Fire #31
    SMG
    I think what Dave is getting at is that the canted angle of the two valves still share the same center-line height from the valve tip, otherwise the WSM would specify the tolerance on those as well.
  22. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,424
    Dumpster Fire #31
    SMG
    Wait,.... how many engineers are in this thread? this could get interesting.. from an engineering perspective that is.. :D
  23. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Correct but that still does not explain how the measurements are done with the Ferrari tool.
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The spring seat surface has no connection to the valve tip install height dimension as per the specification. That surface plays a role but it cannot accurately be used in this measurement as that surface may be cut too low or many be too high. When measuring features, the proper datums must be used.
  25. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,275
    CT
    John Kreskovsky
    #25 johnk..., May 13, 2016
    I can see what DaveRocks is getting at. For the center valve the measurement is obvious. But for the side valves where do you measure to, The center of the valve stem? How would you assure that the gage was so positions? Perhaps the measurement should be made along the axis of the valve? Frankly, that would make more sense to me since the tappets are all the same and the idea is to provide the correct distance from stem tip to cam for the tappet to operate correctly.
